Insm_fe8f17c4
第3楼2024/08/09
仪器为TQS-micro
Column色谱柱: | Waters BEH C18 (2.1×100 mm,1.7 μm) |
Column oven柱温: | 45 °C |
Flow rate流速: | 0.40 mL/min |
Injection volume | 5 μL |
进样量: | |
Sample temperature | 10 °C |
样品盘温度: |
No | Time | Rate | %A | %D | Curve |
(min) | (mL/min) | (5 mmol/L 甲酸铵溶液%) | (乙腈) | ||
1 | Initial | 0.4 | 90 | 10 | Initial |
2 | 0.75 | 0.4 | 90 | 10 | 6 |
3 | 5.3 | 0.4 | 45 | 55 | 6 |
4 | 5.31 | 0.4 | 5 | 95 | 6 |
5 | 5.8 | 0.48 | 5 | 95 | 6 |
6 | 6.5 | 0.5 | 90 | 10 | 1 |
7 | 6.51 | 0.4 | 90 | 10 | 1 |
8 | 7 | 0.4 | 90 | 10 | 1 |
Compound Name | Parent(m/z) | Daughter(m/z) | Dwell(s) | Cone(V) | Collision(V) | RT(min) |
AMPA | 334 | 112* | 0.029 | 20 | 10 | 4.92 |
AMPA | 334 | 156 | 0.029 | 20 | 10 | 4.92 |
glyphosate | 392 | 88* | 0.029 | 20 | 15 | 3.94 |
glyphosate | 392 | 214 | 0.029 | 20 | 10 | 3.94 |
glyphosate-d | 395 | 91 | 0.029 | 25 | 15 | 3.95 |
Glufosinate Ammonium | 404 | 136* | 0.029 | 30 | 15 | 4.31 |
Glufosinate Ammonium | 404 | 208.02 | 0.029 | 30 | 10 | 4.31 |
Glufosinate Ammonium-d3 | 407 | 139 | 0.025 | 30 | 15 | 4.32 |
Insm_613d2c16
第5楼2024/08/09
好的,感恩,我又开始研究了
