MODEL | input voltage | output voltage | output current max | output power | ripple &noise1 Voi/Vo2 | efficiency typ | |
nom | range | max | max | ||||
(Vdc | (Vdc) | (Vdc) | (A) | (W) | (mVp-p) | (%) | |
PRFE20W-072-S5-D | 72 | 8.5~160 | 5 | 4.00 | 20 | 75 | 86 |
PRFE20W-072-S12-D | 72 | 8.5~160 | 12 | 1.67 | 20 | 100 | 89 |
PRFE20W-072-S15-D | 72 | 8.5~160 | 15 | 1.33 | 20 | 100 | 89 |
PRFE20W-072-D12-D | 72 | 8.5~160 | ±12 | ±0.83 | 20 | 100 | 89 |
PRFE20W-072-D15-D | 72 | 8.5~160 | ±15 | ±0.66 | 20 | 100 | 89 |
PRFE20W-072-D24-D | 72 | 8.5~160 | ±24 | ±0.41 | 20 | 100 | 90 |
