型号 | 功率 | 输入电压 | 输出电压可选 |
ECB40W18 | 40W | 8.5~160V | 5V, 12V, 15V, 24V, 48V, 54V |
Pico Part Number | Output Voltage Range (V) | Nominal Output Current (mA) | Output Power Maximum (W) | Efficiency at Full Load Typical (%) | Regulation | Output Voltage Ripple Peak to Peak at Full Load (Vpp) | Output Voltage Setup Tolerance (%) | |
(Maximum) | ||||||||
Line | Load | |||||||
10-20 Vin | 10-100% | |||||||
(%) | Full Load | |||||||
15HIP100 | 10-100 | 500 | 50 | 87 | 0.2 | 0.5 | 0.5 | 0.5 |
15HIP200 | 20-200 | 250 | 50 | 87 | 0.2 | 0.5 | 1 | 0.5 |
15HIP300 | 30-300 | 167 | 50 | 87 | 0.2 | 0.5 | 1.5 | 0.5 |
15HIP400 | 40-400 | 125 | 50 | 86 | 0.2 | 0.5 | 2 | 0.5 |
15HIP500 | 50-500 | 100 | 50 | 86 | 0.2 | 0.5 | 2.5 | 0.5 |
