flying_fish
第2楼2007/06/26
The spectrum of the sample will be compared to the spectrum of the reference material. Both spectra must compare to each other within the resolution allowed by the spectrometer. The number, frequencies (or wavenumbers) and relative intensities of the main peaks in the fingerprint region must be the same for the sample and the standard material.
