【求助】请问 土壤脱氢酶如何测定
  • youyadefeng
    2007/09/19
土壤固体废弃物监测
  • 如题,还有标准曲线如何测定,期待各位老师的解答,谢谢
  • 高卧东山
    第1楼2007/09/20
    土样风干后与TTC(三苯基四唑氯化物)反应,培养一段时间后加甲醇提取,取上清液进行比色测定。
  • 〓疯子哥〓
    第2楼2007/09/20
    http://www.instrument.com.cn/show/download/shtml/054093.shtml
    这个也许对你有帮助
  • xiaoyu311_0
    第3楼2007/09/26
    可以参考如下(包括标准曲线):The dehydrogenase activity analysis, involved the measurement of triphenyl formazan (TPF) produced from the reduction of 2,3,5-triphenyltretrazolium (TTC) (Tabatabai, 1994). Samples of 5 g of air-dried soil were placed in 50-ml centrifuge tubes. To each tube, 1 ml of 3% TTC and 5 ml of deionized water were added. Then the samples were mixed on a vortex, the tubes were stoppered and incubated in the dark for 24 h at 37 ºC. After incubation, 10 ml of methanol were added, the samples were shaken and filtered (Fisherbrand Q8 paper filter). An additional 10 ml of methanol were added to wash the tubes. Then, for calibration, 7 standards of TPF were prepared (0.5, 1, 3, 5, 7, 10 and 15 μg of TPF ml-1). The red-colored complexes were measured within 1 h using the same spectrophotometer as for urease activity but at λ=485 nm.
  • atoto
    第4楼2008/09/18
    非常感谢,我正在测。谢谢
