方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Any small particle that approaches a surface experiences a number of forces before and after contact with the surface. Using an atomic force microscope (AFM) tip, or a small particle attached to an AFM cantilever, the AFM can be used to probe these forces between the tip (or particle of your choice) and a surface. This is done by recording the cantilever deflection as the tip approaches, contacts, and retracts from a surface, then plotting a force curve as a function of the approach-retract travel distance. These types of force measurements can contain information about the electrostatic, chemical, and magnetic properties of surfaces and materials. Because most surfaces being examined are not homogeneous, it is often of interest to collect an array of force curves. Such an array produces information about the lateral distribution of different surface and/or material properties. For example, using a charged tip to probe a surface with patches of charge allows one to localize and characterize the patches on the surface. Previously, obtaining distributions of force curves over an area required manual setting of the x and y offset parameters to each new position in the array. This was tedious and resulted in sparse force sampling of the area. Now collecting this array of data is highly automated on Veeco Instruments AFMs and is referred to as “Force Volume Imaging”.
台阶仪在三维形貌表征领域的应用
3D surface Profi ling applications
双焦面实时超高分辨系统Bruker3DVutura
多功能双光子成像平台Bruker2pplus
高品质双光子成像系统BrukerInvestigator
场扫描共聚焦成像系统BrukerOpterra II
布鲁克透射电镜专用原位纳米力学系统PI 95
布鲁克电镜专用原位纳米力学测试系统PI 88
布鲁克电镜专用原位纳米力学系统 PI 85L
布鲁克高精度纳米力学测试系统TI Premier
布鲁克高精度纳米力学测试系统TI 980
布鲁克三维光学显微镜Contour Elite
摩擦磨损试验机UMT-TriboLab
布鲁克原子力显微镜Dimension FastScan
探针式表面轮廓仪DektakXT
光学轮廓仪NPFLEX 3D
扫描探针显微镜系统Dimension Edge
