台阶仪及AFM在3D MEMS量测中的应用
2008/07/21   下载量: 287
方案下载
应用领域
检测样本
检测项目
参考标准
Stylus profilers are often used to cost effectively measure step heights, bow, planarity, and roughness on the surface of MEMS. The AFP, exclusively available from Veeco, combines the long scan capability of the stylus profiler with the imaging resolution of the AFM, enabling measurement combinations on MEMS that were previously impossible to make with any single metrology tool. Stylus profiling and AFP provide the longest continuous scans of a surface, up to 200mm and 100mm, respectively. Veeco’s Dektak Series stylus profilers and Series Vx AFP benefit from ongoing technology transfer between the various metrology product lines of Veeco. The Dektak Series stylus profilers use the same data analysis software as Veeco’s NT Series Optical Profilers, streamlining the comparison of measurements made on MEMS with these two very different technologies. The AFP uses not only the Veeco NanoScope AFM image analysis software to make measurements on 3-D images it captures, but also core AFM hardware to scan and capture profiles and images of MEMS wafers and devices with unparalleled resolution.
方案下载
上一篇 台阶仪在三维形貌表征领域的应用
下一篇 Thin Film Stress Measurement Using Dektak Stylus Profilers
文献贡献者
相关方案
当前位置: Bruker Nano Surfaces 方案 台阶仪及AFM在3D MEMS量测中的应用
