方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract:The influence of the degree of compression, at deformation rates of 50, 250 and 500 mm min–1, on the textural parameters in the texture profile analysis (TPA) of cylindrical samples of potato and apple tissues was examined. The tests were performed at up to eight different deformation levels ranging from 10% to 80%. The values of all the parameters measured in the samples of both tissues were influenced more by the degree of compression than by the deformation rate. Degrees of compression greater than 40% and 20% caused the rupture of potato and apple specimens, respectively. Regression models were fitted to express the variation of cohesiveness and chewiness with deformation rate and degree of compression. In apple and potato tissues, the degree of compression had a quadratic effect on the cohesiveness while the effect of the deformation rate was only linear. Cohesiveness was the most appropriate textural parameter for detecting effects of deformation rate and degree of compression in TPA tests of potato and apple tissues. Recoverable instantaneous springiness offers a high potential to differentiate the structural natures of different tissues.
冲泡饮品开放式粉体测试
亲水胶体产品质地特性
番茄酱流动特性评估
质构仪 物性测试析仪
包装材料强度质构仪 摩擦系数/剥离强度测试仪
药物制剂多功能物性分析仪 医药分析仪
质构分析仪-物性测试仪Texture Analyser
烟叶梗丝结构仪 烟草质构测试仪 烟草柔韧性分析仪
医药 质构分析仪 物性分析仪- 英国SMS 超技仪器
英国SMS质构仪(物性分析仪)—TA.XT ExpressC
质构仪 重型双臂质构分析仪
英国SMS食品体积测定仪
Calibre C-CELL孔隙组织影像分析系统
英国SMS粉体流变仪
全自动细胞动态培养仪
细胞拉伸仪
Eco Physics氮氧化物分析仪CLD 80/800系列
Eco Physics氮氧化物分析仪CLD 60系列
