create world-leading in-situ electron microscopy solutions
公司简介
CHIPNOVA(超新芯)是早期原位芯片技术开发研究者、国家高层次引进人才创办的高科技企业,致力于为客户提供全面的原位表征方案,并将相关技术应用服务于民用领域。CHIPNOVA拥有MEMS芯片制造和原位电镜方面的资深团队,10余年来产品和技术不断迭代提升,目前已涉及原位芯片、生化医疗芯片、集成传感芯片等。其中原位芯片在材料、催化、能源、环境、化学、生物等领域广泛应用,相关成果发表在Science、Nature子刊等SCI期刊上,服务包括北大、浙大等众多高校和科研单位,推动了相关领域的科技进步。
一、Spring Series In-Situ Holders(透射电镜液体光热电原位系统)
Spring Series In-Situ Holders(液体光热电原位系统)是在原位样品台内部构建小型的液体环境芯片实验室,在液体环境内对材料进行原子分辨高时空精度分析。根据客户需求,结合mems微加工工艺,内置加热模块、光学模块和电学模块,结合透射电镜成像系统,实现对单个纳米材料在热、光、电外场刺激条件下的形貌结构、化学组分、元素价态的原位动态观测,极大扩展了透射电镜的功能与应用领域。
图1 Spring Series In-Situ Holders(透射电镜液体光热电原位系统)
Spring Series In-Situ Holders(透射电镜液体光热电原位系统)可在透射电镜中实现液体样品的电化学反应/加热过程/光学反应过程的实时动态高分辨成像。
应用案例
图2
Structure and composition analysis of Sn@SnOx nanocrystals synthesized by thermal deposition. a Low- and b high-magnification TEM images and c HAADF-STEM image of the Sn-SnOx core-shell structure and corresponding elemental mapping of Sn (green) and O (red).
Peng, X., Zhu, FC., Jiang, YH. et al. Identification of a quasi-liquid phase at solid–liquid interface.Nat Commun 13,3601 (2022). https://- doi.org/10.1038/s41467-022-31075-z
图3
The in situ observation of layer growth dynamics of InCl3.3H2O ultrathin nanosheets. Sequential TEM images of A) the nucleate growth of a single layer, C) the enation growth of a single layer, E) the enation growth of two layers, B,D) the corresponding statistics of the length of growth layer in (A,C) as a function of time, and F) statistics of the angle of enation growth layer in (E) as a function of time, respectively.
Zhang J, Jiang Y, Fan Q, et al. Atomic Scale Tracking of Single Layer Oxide Formation: Self‐Peeling and Phase Transition in Solution[J]. Small Methods, 2021, 5(7): 2001234.
图4
In situ TEM observation of the structural changes of hydrogen evolution active sites under different illumination time.
In situ liquid optics chip: 20 nm silicon nitride.HRTEM images of Cu2O samples with different irradiated time: (a) 1 h, (b) 2 h, (c) 3 h, and schematic diagrams of (d) Cu2O structure change under irradiation.
图5 流体流动及扩散对晶体生长形貌影响观察
efficient co2 reduction mofs derivatives transformation mechanism revealed by in-situ liquid phase tem[j]. applied catalysis b: environmental, 2022, 307: 121164.
图6。光照下环境氛围对纳米团簇演变过程影响
visualizing light-induced dynamic structural transformations of au clusters-based photocatalyst via in situ tem[j]. nano research, 2021, 14(8): 2805-2809.
图7
In situ atomic resolution HRTEM observation on the behaviors of sulfobetaine molecules at the solid-liquid interface under external electric field and the formation of the waterproof layer around the negative electrode surface.
Controlling Interfacial Structural Evolution in Aqueous Electrolyte via Anti-Electrolytic Zwitterionic Waterproofing. Adv. Funct. Mater. 2022, 2207140.
DOI: 10.1002/adfm.202207140
图8/ 图9
HAADF-STEM images and EDS mapping of the porous carbon electrodes with different charging conditions. and the HRTEM images showing the self-aggregation of sulfobetaine in the bulk liquid phase.
二、Volcano Series In-Situ Holders(透射电镜双倾光热电原位系统)
Volcano Series In-Situ Holders(透射电镜双倾光热电原位系统)针对快速变温过程原位高分辨研究需求构建的原位观察平台,根据客户需求结合mems微加工工艺内置加热模块、电学模块和光学模块,通过对样品的外场控制完成热学、电学及光学性质的研究。
Volcano Series In-Situ Holders(透射电镜双倾光热电原位系统),同时涵盖原位双倾功能模块、光学功能模块、电学功能模块、加热功能模块,可在透射电镜中实现固体样品微结构变化的原位表征。在原位双倾转角功能的基础上,通过开创性的将光作为外部条件搭载在原位样品台系统上,结合mems微纳加工制作的超低飘移微区加热芯片,实现全新的双倾-光-电-热四功能耦合,在操作α/β角度转动的同时,可同时引入光场刺激、电场刺激、热场刺激,各功能模块可同时在线工作并且相互独立,互不干扰。
图10 Volcano Series In-Situ Holders(透射电镜双倾光热电原位系统)示意图
应用案例
图11 1300℃恒温,金属合金扩散,芯片温度稳定性好,漂移率低
图12 室温-1000℃变温过程mof材料碳化研究
三、Gravity Series In-Situ Stages(透射电镜高温力学原位系统)
厦门超新芯科技有限公司所研发生产的透射电镜原位高温力学系统是通过在原位样品杆内置力学测量模块、三维纳米运动模块、原位加热芯片,可对材料进行应力及热场条件下原子分辨高时空分析。通过该系统,在透射电镜中通过纳米探针或者原位芯片对样品进行操纵和拉应力、压应力测量。并且在测量样品压力同时实现对样品1000℃的加热,在高温力学测量的同时,能够动态、高分辨地对样品的晶体结构、组分进行综合表征。
具备的功能包括:原位压缩微纳试样进行应力应变曲线监测;原位拉伸微纳试样进行应力应变曲线监测;具有超高精度和灵敏度的力学参数和应变量测试能力,能准确得到定量的载荷和位移的数据,且具有极高的稳定性。特色功能:恒定载荷控制功能,以适用于材料的蠕变特性研究;恒定位移控制功能,以适用于材料的应力松弛的研究。
图13 Gravity Series In-Situ Stages(透射电镜高温力学原位系统)示意图
应用案例
图14/图15 纳米碳球压缩原位力学实验
图16 钨纳米棒原位压缩过程
设备更新|超新芯电镜系列产品申报目录
超新芯科技产品选型指南:高端国产替代,助力科研创新
喜报 | “发现锂硫电池界面电荷存储聚集反应新机制”入选2023年度“中国科学十大进展”
喜讯 | 廖洪钢教授荣获第十二届中国化学会-巴斯夫公司青年知识创新奖
