6-氨基己酸6-Aminocaproic acid発行日:2013年8月発行人:株式会社資生堂7)了7仁事業部 6-氨基己酸(E-氨基己酸)具有止血作用,被添加到各种产品中广泛使用。使用 CAPCELLCORE PC S2.7 (2.1 mm i.d.x150 mm), 在HILIC模式下进行分析,氨基己酸得到了充分的保留,且色谱峰形良好。 6-Aminocaproic acid, or e-aminocaproic acid, is formulated as a hemostatic agent in manyproducts. The following chromatogram was obtained with CAPCELL CORE PC S2.7(2.1mm i.d. x 150 mm), where the compound was adequately retained, showing a nice peakshape (HPLC Conditions】 Column :CAPCELL CORE PC S2.7 ; 2.1 mm i.d. x 150 mmMobile phase : 20 mmol/L Phosphate buffer (KH2PO4:Na2HPO4=1: 1)/CH3CN=30/70Flow rate :400 pL/minTemperature :40cDetection :PDA210 nmInj. vol. : 10 pLSample dissolved in : The standard compound was dissolved in water at 1 mg/mL.The solution was further diluted five-fold with CH3CN. ※ 1 ug/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《氨基己酸中CORE PC快速分析检测方案(液相色谱柱)》,该方案主要用于原料药中含量测定检测,参考标准《暂无》,《氨基己酸中CORE PC快速分析检测方案(液相色谱柱)》用到的仪器有null。
