WINDOW FOR NANO WORLD with COXEM16 Smartphones Overview Not only physicists or microscopists, but also electronic engineers can use SEM to gain better understandings ofsmartphones. Electronic Display Board The following sample is an electronic board used fordisplay. The board entails a specific pattern. BSE mode givessupplementary sample information by providing a differentkind of image that the SE mode cannot, such as informationon the surface morphology. E SEX1,500,20kV X1,500,20kV Otherlmages 20.0[KV] COXLH Display(x5,000) Film (x1,000) Coating (x10,000) Not only physicists or microscopists, but also electronic engineers can use SEM to gain better understandings of smartphones.
关闭产品配置单
北京天耀科技有限公司为您提供《材料学中表面形态分析检测方案(扫描电镜)》,该方案主要用于信息技术类设备中表面形态分析检测,参考标准《暂无》,《材料学中表面形态分析检测方案(扫描电镜)》用到的仪器有库赛姆(COXEM)EM-30+ 台式扫描电镜。
