汽油中碳氢化合物和苯系物的分离 Column: NanoChrom BP-FFAP Dimension: 60mx0.32mmx0.50um Carrier: Hydrogen, 1.3 mL/min (Constant Flow) Inlet: Split, 240 ℃, Split flow 50ml/min Oven: 45℃ (hold 5min) to 120℃ (hold 1min) at 5℃/min Inject volume: 0.1 pL Detector: FID 260℃ Peak# Compound Retention time (min) Resolution 1 Pentane(戊烷) 4.420 2 Hexane(己烷) 4.685 3 Tert-butyl methylether (MTBE)(叔丁基甲醚) 4.755 2.18 4 Acetone(丙酮) 5.427 5 Ethyl acetate(乙酸乙酯) 7.575 6 2-Butanone(2-丁酮) 9.079 7 Methanol(甲醇) 9.400 8 Isopropanol(异丙醇) 9.991 9 Ethanol(乙醇) 10.183 10 Benzene(苯) 10.367 11 1-propanol(正丙醇) 12.334 12 Toluene(甲苯) 12.494 3.85 13 Iso-butanol(异丁醇) 13.321 14 1-Butanol(1-丁醇) 14.595 Peak#CompoundRetention time (min)Resolution1Pentane(戊烷)4.4202Hexane(己烷)4.6853Tert-butyl methyl ether (MTBE)(叔丁基甲醚)4.7552.184Acetone(丙酮)5.4275Ethyl acetate(乙酸乙酯)7.57562-Butanone(2-丁酮)9.0797Methanol(甲醇)9.4008Isopropanol(异丙醇)9.9919Ethanol(乙醇)10.18310Benzene(苯)10.367111-propanol(正丙醇)12.33412Toluene(甲苯)12.4943.8513Iso-butanol(异丁醇)13.321141-Butanol(1-丁醇)14.595
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《汽油中碳氢化合物和苯系物检测方案 》,该方案主要用于汽油中组成分析检测,参考标准《暂无》,《汽油中碳氢化合物和苯系物检测方案 》用到的仪器有纳谱分析 NanoChrom BP-FFAP 强极性毛细管柱。
