ATR的使用是一种快速有效的红外测量方法。当使用ATR时,有必要正确设置并按压棱镜中心的样品,以获得高质量的数据,尤其是在测量可能小于棱镜的微样品时。JASCO的最新配件ATR PRO ONE VIEW具有观察功能,可定位理想的测量位置,同时在前监视器或PC上显示样本区域。在这个应用说明中,我们测试了几种美容睫毛。有许多不同类型的用于美容目的的假睫毛,根据材料标签,它们被声称是由人的头发、动物的头发或天然纤维制成的。然而,假睫毛通常被标记为来自动物来源,而实际上它们是由合成织物制成的。这里使用ATR PRO ONE VIEW对人声称为人发的人睫毛和假睫毛进行分析评估。本应用中结论:ATR PRO ONE VIEW是一种快速、有效的测量微样品的工具,在这种情况下,假睫毛的主要成分被鉴定为聚酯。 一般来说,微样品无损分析技术的应用对于异物分析、刑事调查和虚假标记具有重要意义。 结果表明,ATR PRO ONE VIEW在各种应用领域的无损微样品分析中都是非常有效的。 因为ATR PRO ONE VIEW不仅提供分析信息,还提供样本视图和大小等空间信息。Application Note130-AT-0244 2/2Micro Sample Analysis usingApplication NoteATR PRO ONE VIEW Micro Sample Analysis using ATR PRO ONE VIEW I ntroduction The use of ATR is an effective method for fast and efficient IR measurement. When using ATR, it i s n ec e ssary to cor r ec t ly s e t and press t he sample at the c e n te r of t h e prism to o b tain good quality data, espec i ally when measuring a m icro sample which may be smal l er t han the prism. JASCO's la t est accessory, t h e ATR PRO ONE VIEW has an observation function to l ocate the id e a l meas u rem e nt position, while di s play i ng the sample a r ea on th e front mo n ito r or PC. In t his a pp l ica ti on note we test e d s e ver a l cosmet i c e y el as h es. There a re m any di ff erent t ypes of false eyelashes for cosmetic purpose, whic h are claimed to be made from human hai r , a ni mal ha i r , or natural f i bers according to t h e m aterial la b eling. H owever, false eyel a shes are ofte n labe l ed as f rom animal so ur ces whe n in fact t h ey a r e made fr o m synthet i c fabric. The analytical evaluation between human eyelashes and fa l se Figure 1. A TR PRO ONE V I EW eye l ashes c l aimed as huma n hair is ma d e her e using the ATR PRO ONE VIEW. Measurement I n stru m ents F T /I R -4600 K eyword s Resolu tion 4c m² Micro sample, Material analysis, ATR M et h od ATR Detecto r DLA TG S A cc um ula t io n 50 t imes M easu r emen t M ethod A cces s ory AT R P R O O N E V I EW Set the human eyelash and the false eyelash claimed as human hair commercially on the ce n ter of t h e prism usi n g the monitor. Measurement conditions are shown be l ow. P r i sm P KS-D 1V Resu l t F i gure 2 shows the sample i mages a n d the IR spectra of a human eyelas h and a false eyelash . As shown i n the i mages,t h e samples we r e set a t t h e center of the prism. Peaks der i ved from Amide l, I l are detected around 1640 cm -a n d 1550cm - i n the h uma n eye l as h IR spectrum, which means t h at main componen t of human eyelash is prote i n. The spec t rum of the false eyelash IR is different from human's,and i nd i cates the existence of a synthetic f i ber. The mai n component was i de n tifi e d as po l y b u t y l en e te rep ht h alate by database searc hin g . 0.08 0.4 0.06 0.3 100 um 100 um 0.04 0.2 Abs Abs 0.02 0.1 0 0 4000 3000 2000 1000 500 4000 3000 2000 1000 500 Wavenumber[cm'] W a venumber[cm'] Figure 2. I R s p ectra of h uman eyelash (lef t ) an d false eyelash (r ight) Figure 3. I R s p ectra of p oly b uty l ene terep h th a l a te stan d ard (top) and fa l se eye l ash (b ot t om) Conc l usion T he ATR PRO ONE VIEW is a fast and effective tool for m easuring m i c r o samples , i n t his case t h e mai n component of the false eyelash was ident i f i ed as polyester. In general, the appl i cation of non-destructive analyt i cal tech n iques f or mic r o samples i s very importan t for foreig n material analysi s , cr i mi n al i n vestiga ti on an d false lab e lin g . This note s hows that ATR PRO ONE VIEW is hig h ly effe ctive for non-destruc t ive mic r o sample analysis in a variety of app l ica t ion fie l ds. Because the ATR PRO ONE VIEW provides not only analytical information bu t also spatial information like sample view and size. JASCO
关闭产品配置单
佳士科商贸有限公司为您提供《使用ATR PRO ONE VIEW进行微量样品分析》,该方案主要用于毛发/头发中微样品、异物、毛发鉴定检测,参考标准《暂无》,《使用ATR PRO ONE VIEW进行微量样品分析》用到的仪器有JASCO FTIR-4000傅立叶变换红外光谱仪。
