poorlittle
第1楼2007/11/21
Nanotechnology is a relatively new science, some terms may not have official Chinese translation. If you are familiar with this subject, why don’t you consider to create a Chinese translation by yourself.
Same suggestion to the post “这个词怎么查不到呀” http://www.instrument.com.cn/bbs/shtml/20071110/1053522/
(your proposed translation may also be posted to Wikipedia 維基百科
http://zh.wikipedia.org/wiki/%E7%BA%B3%E7%B1%B3%E7%A7%91%E6%8A%80 if you are quite sure that there is still no official Chinese translation so far.)
遨翔的岁月
第2楼2007/11/21
我说,专业一点
这是专业英语呀
不是化学、物理专业的当然不懂了。
闲鹤野云
第3楼2007/11/21
Digestive ripening, heating a colloidal suspension at or near the solvent boiling point in the presence of a surface-active ligand, was applied to polydisperse colloidal gold in toluene using a series of alkylthiols, viz., octyl-, decyl-, dodecyl-, and hexadecylthiols. In all the instances, digestive ripening significantly reduced the average particle size and polydispersity. All-the colloids remain suspended in solution above 80 degreesC, but at room temperature the tendency to form 3D superlattices and precipitate increased with declining alkyl chain length. For example, using octanethiol as the ligand makes the colloids aggregate into big 3D superlattices and precipitate; decane- and dodecanethiol also produce precipitated 3D superlattices along with separate particles, while hexadecanethiol-coated particles remain well separated from each other. The optical spectra at room temperature reveal, apart from the gold plasmon band at 530 nm, a large tail above 700 nm for Au-octanethiol and Au-decanethiol cases and a shoulder at 630 nm for Au-dodecanethiol attributed to the superlattices. Au-hexadecanethiol, on the other hand, shows only the gold plasmon band as expected from separate particles. However, at higher temperatures only the gold plasmon band is observed for all the colloids indicating the dissolution of the superlattice. The aggregation of the particles into 3D superlattices or their stability as a colloidal suspension is qualitatively explained on the basis of decreasing van der Waals attraction between the gold nanoparticles as the separation between them is increased through the alkyl chain length of the capping ligand from octyl to hexadecyl.
消融熟化???消解熟化??消熟过程??
happyjxy1989129
第6楼2007/11/22
偶也不懂,和和,如果需要什以标准 品,到国家标准物质网那里看看好了,
那里的产品很全,服务也发。和和
www.rmhot.com
www.gbw800.com
rmhot@163.com
