透射电子显微学中常用的缩写词
专业英语
  • http://www.instrument.com.cn/bbs/shtml/20051226/310352/
    原文由ustb版主发表:ACF absorption correction factor
    A/D analog to digital (converter)
    ADF annular dark field
    AEM analytical electron microscope/microscopy
    AES Auger electron spectrometer/spectroscopy
    AFF aberration-free focus
    ALCHEMI atom location by channeling-enhanced microanalysis
    APB anti-phase domain boundary
    ATW atmospheric thin window
    BF bright field
    BFP back focal plane
    BSE backscattered electron
    BSED backscattered-electron diffraction
    BZB Brillouin-zone boundary
    C(1,2,etc..)condenser (l, 2, etc.) lens
    CB coherent bremsstrahlung
    CBED convergent-beam electron diffraction
    CBIM convergent-beam imaging
    CCD charge-coupled device
    CCF cross-correlation function
    CCM charge-collection microscopy
    CDF centered dark field
    CF coherent Fennel/Foucault
    CFEG cold field-emission gun
    CL Cathodeoluminescence
    CRT cathode-ray tube
    CS crystallographic shear
    CSL coincident-site lattice
    DF dark field
    DOS density of states
    DP diffraction pattern
    DQE detection of quantum efficiency
    DSTEM dedicated scanning transmission electron microscopy
    DTSA desktop spectrum analyzer
    EBIC electron beam-induced current/conductivity
    EELS electron energy-loss spectrometry
    EFI energy-filtered imaging
    ELNES energy-loss near-edge structure
    ELP energy-loss program (Gatan)
    EMMA electron microscope microanalyzer
    EMS electron microscopy image simulation
    EPMA electron probe microanalyzer
    ESCA electron spectroscopy for chemical analysis
    ESI electron spectroscopic imaging
    EXAFS extended X-ray absorption fine structure
    EXELFS extended energy-loss fine structure
    FCF fluorescence correction factor
    FEG field-emission gun
    FET field-effect transistor
    FFT fast Fourier transform
    FOLZ first-order Laue zone
    FSE fast secondary electron
    FTP file transfer protocol
    FWHM full width at half maximum
    FWTM full width at tenth maximum
    GB grain boundary
    GCS generalized cross section
    GIF Gatan image filter
    GOS generalüed oscillator strength
    HAADF high-angle annular dark field
    HOLZ higher-order Laue zone
    HPGe high-purity germanium
    HRTEM high-resolution transmission electron microscope/microscopy
    HV high vacuum
    HVEM high voltage electron microscope/microscopy
    IDB inversion domain boundary
    IEEE International Electronics and Electrical Engineering
    IG intrinsic Ge
    IVEM intermediate voltage electron microscope/microscopy
    K-M Kossel-Möllenstedt
    LEED low-energy electron diffraction
    LLS linear least-squares
    LUT look-up table
    MC minimum contrast
    MCA multichannel analyzer
    MDM minimum detectable mass
    MLS multiple least-squares
    MMF minimum mass fraction
    MSDS material safety data sheets
    NCEMSS National Center for Electron Microscopy simulation system
    NIH National Institutes of Health
    NIST National Institute of Standards and Technology
    OR orientation relationship
    OTEDP oblique-textured electron diffraction pattern
    PB phase boundary
    P/B peak-to-background ratio
    PEELS parallel electron energy-loss spectrometer/spectroscopy
    PIMS Precision Ion-Milling System
    PIPS Precision Ion-Polishing System
    PM photomultiplier
    POA phase-object approximation
    QHRTEM quantitative high-resolution transmission electron microsc.
    RB translation boundary (yes, it does!)
    RCP rocking-beam channeling patterns
    RDF radial distribution function
    REM reflection electron microscope/microscopy
    RHEED reflection high-energy electron diffraction
    RHF relativistic Hartree-Fock
    RHFS relativistic Hartree-Fock-Slater
    SAD selected-area diffraction
    SE secondary electron
    SEELS serial electron energy-loss spectrometer/spectrometry
    SEM scanning electron microscope/microscopy
    SF stacking fault
    SHRLI simulated high-resolution lattice images
    SIMS secondary ion mass spectrometry
    S/N signal-to-noise ratio
    SOLZ second-order Laue zone
    SRM standard reference material
    STEM scanning transmission electron microscope/microscopy
    STM scanning tunneling microscope/microscopy
    TB twin boundary
    TEM transmission electron microscope/microscopy
    TMBA too many bloody acronyms
    UHV ultrahigh vacuum
    UTW ultra thin window
    V/F voltage to frequency (converter)
    VLM visible-light microscope/microscopy
    WB weak beam
    WBDF weak-beam dark field
    WDS wavelength-dispersive
    WP whole pattern
    WPOA weak-phase object approximation
    WWW World Wide Web
    XANES X-ray absorption near-edge structure
    XEDS X-ray energy-dispersive
    XRD X-ray diffraction
    YBCO yttrium-barium-copper oxide
    YAG yttrium-aluminum garnet
    ZAF atomic number, absorption, fluorescence correction
    ZAP zone-axis pattern
    ZOLZ zero-order Laue zone
  • 该帖子已被管理者-设置为精华,下面是奖励记录:
  • 第1楼2005/12/26
    谢谢shxie大哥支持,动作这么快,
    我有一事请教,我不懂怎么把帖子转移到子版?
  • 第3楼2005/12/26
    先建好子版,然后按版面管理--点选帖子前面的方框,相近的分类--版面内批量转移帖子--选中你要转移的子版即可,每页里有30个帖子,建议顺序转移比较好一些。
    wrliao 发表: 谢谢shxie大哥支持,动作这么快,
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加3积分,加3声望
  • 第4楼2005/12/26
    呵呵呵呵,终于明白了(原先傻乎乎的,一直选择第二个选项所以永远也不会出现转移到子版的选项),谢谢shxie大哥指点
    嘿嘿,提出点小小要求哦,如果把中文对照翻译也一并上来更完美哦,嘻嘻
  • 第5楼2005/12/26
    嗯,不过我的确很多词翻译不准确,还是请ustb版主来吧,嘿嘿。
    wrliao 发表:呵呵呵呵,终于明白了(原先傻乎乎的,一直选择第二个选项所以永远也不会出现转移到子版的选项),谢谢shxie大哥指点
  • 第6楼2005/12/26
    太多了,等我翻译好了再发上来。我在资料中心上传了一个英汉科技词典,好多科技词汇都查的到,个人感觉不错。
    http://www.instrument.com.cn/show/download/shtml/016354.shtml
    shxie 发表:嗯,不过我的确很多词翻译不准确,还是请ustb版主来吧,嘿嘿。
  • 第8楼2005/12/26
    啊,盗版被抓住了,哈哈。那个字典据说的确不错的,建议大家下载:)
    ustb 发表:太多了,等我翻译好了再发上来。我在资料中心上传了一个英汉科技词典,好多科技词汇都查的到,个人感觉不错。
  • 第9楼2005/12/27
    谢谢谢谢,谢谢两位斑竹支持
  • 第10楼2005/12/27
    ^_^,不管了,跟大家分享一下。
    shxie 发表:啊,盗版被抓住了,哈哈。那个字典据说的确不错的,建议大家下载:)
