闲鹤野云
第8楼2007/11/28
总感觉这个句子晦涩难懂。
Chirality of the active substance, with all the isomers forms and specific rates, that can influence on the efficiency and also on the security(stability??) of the activesubstance. Always present assay results of the isomers when the analysis methodology is available. In case of If the active substance presents chirality, the manufacture should send a statement about this situation (?).
happyjyl
第9楼2007/11/28
这里的security是指药物的安全性(有没有副作用和毒性等)。stability是指药物的稳定性(在某种贮存条件下经过多长时间会降解而失效)。
