poorlittle老师,您好。fortified sample不是指残留,而是指在分析的时候所添加的。目的是做方法的添加回收率,所以不是残留的农药。
不过我发现很多地方也写fortified pesticide resdiue。
要不这样翻译,添加的农药残留和原有的农药残留??
poorlittle 发表:Both fortified pesticides and incurred pesticides are残留农药, 但成因不同。 fortified pesticides 源自直接施加于农作物的农药, incurred pesticides 是由animal and environment间接传过来的. If incurred pesticides is simply translated as 残留农药, I am afraid that it may cause ambiguous.
