The Liquid-Liquid Extraction Behaviour of Copper(Ⅱ) Based on Sodium Chloride-Sodium-Diethyldithiocarbamate-n-Propanol System
LI Quan-min,ZHANG Li-min,LIU Qi and GUO Jin-zhi(Department of Chemistry,Henan Normal University,Xinxiang 453002),Fenxi Shiyanshi,1999,18(2):20~23
In this paper,the liquid-liquid extraction behaviour of the chelate of copper(Ⅱ) with sodium diethyldithiocarbamate based on sodium chloride-sodium diethyldithiocarbamate-n-propanol system was investigated and the proper conditions of phase separation of n-propanol and water were selected.The quantitative extraction separation of Cu2+ from Fe3+,Co2+,Ni2+ and Al3+ was carried out by adding 1.0mL of 0.001mol/L EDTA as the masking agent to 10mL 30%(V/V) n-propanol solution at pH 7.0 .The separation results are satisfactory. Keywords Sodium chloride;sodium diethyldithiocarbamate ;n-propanol;copper;extraction separation
