【求助】求文献(外文)!
文献检索-互助
  • 急求文献!谢谢大家帮忙!
    Liquid-Phase MethanolsFinal Report; U.S. Department
    of Commerce NTIS Report, Cooperative Agreement No. AF 1291;
    December, 1979.
    2、
    Peng, X. D.; Toseland, B. A.; Undrwood, R. P. A novel
    mechanism of catalyst deactivation in liquid-phase synthesis gasto-
    DME reaction; Proceedings of the 7th International Catalyst
    Deactivation Symposium, Cancun, Mexico, Oct 1997.
  • hanxm
    第1楼2008/05/05
    第2篇可以在“学术google”以题名检索,第2条信息就是的。只是有点可惜有两页看不到(版权问题)
    A Novel Mechanism of Catalyst Deactivation in Liquid Phase Synthesis Gas-to-DME Reactions
    XD Peng, BA Toseland, RP Underwood - Catalyst Deactivation 1997, 1997 - books.google.com
    e! 997 Elsevier Science BV All rights reserved Catalyst Deactivation 1997 CH
    Bartholomew and GA Fuentes, editors 175 A Novel Mechanism of Catalyst Deactivation
    in Liquid Phase Synthesis Gas-to-DME Reactions XD Peng*, BA Toseland and RP Underwood ...
    被引用次数:3 - 相关文章 - 网页搜索
  • 亮剑
    第2楼2008/05/05
    谢谢楼上的!还请各位多多帮忙!
  • huier1223
    第3楼2008/05/26
    没有办法下不良。
    有摘要
    A novel mechanism of catalyst deactivation in liquid phase synthesis Gas-to-DME reactions
    X.D. Penga, B.A. Toselanda and R.P. Underwooda
    aAir Products and Chemicals, Inc., 7201 Hamilton Boulevard, Allentwon, PA 18195-1501, USA
    Available online 18 June 2007.
    This article is not included in your organization's subscription. However, you may be able to access this article under your organization's agreement with Elsevier.
    Commercial methanol synthesis catalysts and γ-alumina are stable when used separately in a slurry phase reactor for the methanol synthesis and the methanol dehydration reaction, respectively. However, when they are used as a physical mixture for our slurry-phase synthesis gas-to-DME process, both catalysts deactivate rapidly. Traditional causes of catalyst deactivation, including hydrothermal sintering, leaching, coking, and poisoning, were investigated and subsequently ruled out. Detrimental interaction between the two catalysts was identified as the cause of the rapid, simultaneous deactivation of both catalysts. Intimate solid-state contact between the two catalysts is necessary for this interaction to take place. Most likely, the interaction is due to the migration of Zn-and Cu-containing species from the methanol catalysts to γ-alumina. Although not discussed in this paper, a proprietary dual catalyst system with good stability has been developed.
  • 该帖子已被版主-大陆加1积分,加2经验;加分理由:貌似并非楼主所要,有些相关,为热心加分!
