【求助】应助一句话翻译…8
  • chengjingbao
    2008/05/27
专业英语
  • 悬赏金额:10积分状态:已解决
  • NOTE: The flow control valve is a miniature thermal valve. On power up the valve is cold. It may take up to two minutes before to have flow trough this valve 。 Once the valve is warm the flow will stabilize. If you put the flow set point to 0 cc for a
    while the valve will cool down again.
    注意:流量控制阀是一个微型热导式调节阀。启动时,阀是冷的。在有流量通过这个阀之前两分钟,它开始运行。一旦阀被加热,流量将可以稳定。如果你将流量设定为0 CC,热导阀将再冷下来。
    请各位专家再帮我看看这句话,特别是划线部分,它很重要,我翻的对不对?!!先谢谢各位啦!
youjian000 2008/05/27
我的理解是:由于刚启动时,阀是冷的,所以短时间内应没有流量通过该阀。阀的加热是需要时间的,它最多可能需花费两分钟来进行加热,然后才有流量通过该阀。
社区=冬季= 2008/05/27
[quote]原文由 [B]yinhjcom[/B] 发表: 应该还可以吧。[/quote] 真的可以吗?[em0801]
learner1999 2008/05/27
[quote]原文由 [B]chengjingbao[/B] 发表: NOTE: The flow control valve is a miniature thermal valve. On power up the valve is cold. [U]It may take up to two minutes before to have flow trough this valve 。[/U] Once the valve is warm the flow will stabilize. If you put the flow set point to 0 cc for a while the valve will cool down again. 注意:流量控制阀是一个微型热导式调节阀。启动时,阀是冷的。[U]在有流量通过这个阀之前两分钟,它开始运行。[/U]一旦阀被加热,流量将可以稳定。如果你将流量设定为0 CC,热导阀将再冷下来。 请各位专家再帮我看看这句话,特别是划线部分,它很重要,我翻的对不对?!!先谢谢各位啦![/quote] 你这原本应该是汉译英吧?"it may take two minutes before the flow pass through this valve","once the valve is warmed"
poorlittle 2008/05/27
My understanding, from literal point of view only, is that in order to ensure a stabilized flow, the valve should be pre-heated before allowing the fluid to flow through the valve, and it will take about 2 minutes for this pre-heating procedure. 需等约两分钟才可让流动相通过此阀 需等约两分钟才可用此阀
  • yinhjcom
    第1楼2008/05/27
    应该还可以吧。
  • 社区=冬季=
    第2楼2008/05/27
    真的可以吗?
    yinhjcom 发表:应该还可以吧。
  • chengjingbao
    第3楼2008/05/27
    谢谢楼上的肯定,还请发表自己的意见。因为划线部分,与我日常操作仪器时略有出入,次序正好相反,这将对仪器寿命和热导调节阀的寿命有直接影响。如果翻译没错,那我的日常工作就有错!只是平常操作时动作较快,没有造成损伤罢了。但不当的操作方法迟早会酿成大错,请各位畅所欲言!重点对划线部分进行纠正。
    lylsg555 发表:真的可以吗?
  • learner1999
    第4楼2008/05/27
    chengjingbao 发表:NOTE: The flow control valve is a miniature thermal valve. On power up the valve is cold. It may take up to two minutes before to have flow trough this valve 。 Once the valve is warm the flow will stabilize. If you put the flow set point to 0 cc for a
  • youjian000
    第5楼2008/05/27
  • 该帖子已被版主-何当奇加5积分,加2经验;加分理由:多谢参与讨论
  • 何当奇
    第7楼2008/05/27
    划线部分直译就是”需要两分钟时间在流过此阀之前。“
    整理下语序,就是在流动相通过此阀之前,需要有两分钟(预热时间)。从整句来看,这两分钟是此阀的预热时间。
  • poorlittle
    第8楼2008/05/27
    需等约两分钟才可让流动相通过此阀
    需等约两分钟才可用此阀
  • chengjingbao
    第9楼2008/05/27
    回楼上:这是来自加拿大的英文说明。
    learner1999 发表:你这原本应该是汉译英吧?"it may take two minutes before the flow pass through this valve","once the valve is warmed"
  • chengjingbao
    第10楼2008/05/27
    这就是我想请教专家的原因了!按热导原理说,其阀功能应该有此特点。但我对字面意思的理解是,先加热阀即调节阀通电,再通气。而我们实际操作情况是:先通气,再通电。要将意思确定再说。
    youjian000 发表:我的理解是:由于刚启动时,阀是冷的,所以短时间内应没有流量通过该阀。阀的加热是需要时间的,它最多可能需花费两分钟来进行加热,然后才有流量通过该阀。
  • 何当奇
    第11楼2008/05/27
    这个字面意思非常清楚,没有任何异议
    chengjingbao 发表:这就是我想请教专家的原因了!按热导原理说,其阀功能应该有此特点。但我对字面意思的理解是,先加热阀即调节阀通电,再通气。而我们实际操作情况是:先通气,再通电。要将意思确定再说。
