manxisuo 2008/06/15
I think that that that that that student wrote on the blackboard was wrong. 第一个that:think后面的宾语从句的引导词 第二个that:“那个”的意思 第三个that:表示“that”这个单词 第四个that:定语从句的引导词that 第五个that:“那个”的意思 翻译:我认为那个学生在黑板上写的那个“that”是错误的。 分析:think后面跟一个宾语从句“that that that that student wrote on the blackboard was wrong”。其中宾语从句的主语为“that that”,意为“那个that”。宾语从句的主语由一个定语从句(that that student wrote on the blackboard )来修饰。
youjian000 2008/06/14
分解如下: I think 我认为 that(引导宾语从句) that that 那个that that (引导定语从句) that student wrote on the blackboard 那个学生在黑板上写的 was wrong. 是错的。 整句翻译:我认为,那个学生在黑板上写的那个that是错的。
crazylovecat 2008/06/16
[quote]原文由 [B]happyjyl[/B] 发表: I think that that that that that student wrote on the blackboard was wrong. [B][color=#DC143C]赏分标准:给出正确答案的同时还要写出自己对句子结构和有关知识点的理解和分析。如果只给出了正确的翻译,没有给出自己的分析,或仅仅是同意别人的观点,这样是不能得分的。请同志们注意。[/color][/B] [/quote] I think that(引宾语从句) that(前置定语修饰后面那个that) that(被修饰限定的that) that(引定语从句) that(前置定语修饰student) student wrote on the blackboard was wrong. 解释为:我认为那个学生写在黑板上的那个“那个”是错的。(翻译中出现3个that的实意,另2个为引导词,不翻译)
33336666 2008/06/16
I think that that that that that student wrote on the blackboard was wrong. 我认为那个学生写在黑板上的那个that是错误的。 第一个that:引导宾语从句 第二个that:那个的意思,修饰第三个that 第三个that:就是名词that,被第二个that修饰 第四个that:其实可以去掉 第五个that:那个的意思,修饰student
chengjingbao
第4楼2008/06/14
我试解一下:第一that 那个;
第二个是我认为的事,一二相连,即个事,可做宾语;
第三个that用来引导从句,解释一二相连所叙述的事;
最后一个that是那个的意思;
第四个不清楚;
意思是说:我认为那个事,什么事?学生在黑板上写字是错误的那个事?
也有一解:我认为的事,什么事?学生在黑板上写字,是错误的。此解强调了自己,承认了错误。我的解释倾向于后者。
立静致远
第8楼2008/06/14
[quote]原文由 happyjyl 发表:I think that that that that that student wrote on the blackboard was wrong.
试下问答。
一共有5个that,从头到尾分别记为1,2,3,4,5
第五个that,是修饰 student,那个学生
第四个that是宾语从句,在wrote后面
第三个that是主语从句,修饰that student wrote on the blackboard
第二个that是that, 指学生写在黑板上的那个that
第一个that是宾语从句,指think what。
hrcren
第12楼2008/06/14
翻译:我觉得那个学生写在黑板上的那个“that”是错的
分析:
I think that {that that [that that student wrote on the blackboard was wrong.]}
I think,是主谓,第一个that,相当于宾语,后面大括号里面的一长串都是修饰这第一个that的;
第二个that是冠词,修饰第三个that,表示“那个that”;版主点评:that是代词,不要跟冠词搞混了。
第三个that是名词,后面中括号里面一长串是修饰第三个that的
第四个that修饰第三个that,相当于which,具体叫什么名儿我忘了
第五个that当然就是修饰student的了,表示“那个学生”
这些合起来就是上面那句话,当然没有每个that都翻译出来,不知对否
