我在故我思
第1楼2008/07/04
楼主,你好!下次请您还是尽量找一下全文的下载链接,给应助者提供便利。其实根据作者是可以找到链接的。
J. Chem. Soc., Faraday Trans. 2, 1979, 75, 790 - 798, DOI: 10.1039/F29797500790
Plasma resonance enhancement of Raman scattering by pyridine adsorbed on silver or gold sol particles of size comparable to the excitation wavelength
J. Alan Creighton, Christopher G. Blatchford and M. Grant Albrecht
Intense Raman scattering by pyridine molecules adsorbed on silver or gold aqueous sol particles of dimensions comparable to the wavelength is reported. The degree of intensity enhancement is strongly dependent on the excitation wavelength, with a sharp resonance Raman maximum for excitation at the wavelength of the Mie extinction maximum of the metal particles, and for the silver sols the Raman maximum is shown to follow the extinction maximum to longer wavelengths with increase in particle size. A new resonance Raman phenomenon is thus proposed which is the Raman component of resonant Mie scattering, and in which the polarizability of the metal particles is modulated by the vibrations of the adsorbed molecules. These observations confirm that surface plasma oscillations are involved in the intense Raman scattering already reported for molecules adsorbed at roughened silver surfaces. The metal dielectric function requirements for resonant Mie scattering enable the optimum excitation wavelength for plasma resonance-enhanced Raman studies at the surface of other metals to be estimated.
我在故我思
第2楼2008/07/04
