happyjyl
第2楼2008/08/27
吸光度:absorbance
投射比:transmittance
吸收峰:absorption
红移:red shift
立体化学效应:stereochemical effect
空间位阻:steric hindrance
跨环效应:cross-ring effect
溶剂效应:solvent effect
单光束分光光度计:single beam spectrophotometer
双光束分光光度计:double beam spectrophotometer
双波长分光光度计:double wavelength spectrophotometer
多通道分光光度计:multichannel spectrophotometer
光导纤维探头式分光光度计:optical fiber probe-type spectrophotometer
示差分光光度法:differential spectrophotometry
happyjyl
第3楼2008/08/27
连续滴定:continuum titration
转换技术:conversion techniques
进样阀:valve for injection
串联质谱法:tandem mass spectrometry
激光微探针质谱法:laser microprobe mass spectrometry
二次离子质谱法:secondary ion mass spectrometry-SIMS
离子探针微区分析:ionprobe microanalysis
离子回旋共振分析器:ion cyclotron resonance-ICR
离子阱检测器:ion trap detector
四极滤质器:quadrupole mass filter
飞行时间分析器:time of flight-TOF
happyjyl
第4楼2008/08/27
傅立叶变化红外光谱仪:Fourier transform infrared spectrometer(FTIR)
拉曼光谱:Raman spectrum
荧光猝灭:fluorescence quenching
激光诱导荧光法:laser-induced fluorometry(LIE)
荧光免疫分析法:time-reslolved fluoroimmunoassay
荧光偏振:fluorescence polarization
同步荧光分析:synchronous fluorometry
原子发射光谱法:atomic emission spectrometry(AES)
原子吸收光谱法:atomic absorption spectrometry(AAS)
原子荧光光谱法:atomic fluorescence spectrometry(AFS)
原子质谱分析法:atomic mass spectrometry(AMS)
