平凡人
第1楼2008/10/08
【名称】EPA spectral database
【资源简介】
EPA Reference Absorbance Spectra
The Clean Air Act Amendments (CAAA) was published in November 1990. Title III of the Clean Air Act includes a list of 189 hazardous air pollutants (HAPS) for which test methods must be established. An extractive stack sampling method, using FTIR, has been developed for measuring HAPS. As one of the initial tasks in the project development, reference spectra were developed for as many of the HAPS as possible. Attached is a table which contains the quantitative reference spectral library as of June 1993. The table includes several columns of information for each file. The pathlength is the pathlength of the sample cell used to record that particular spectrum. The TEMP column is the temperature at which the compound was measured. Spectra were recorded for each compound at for at lease two different concentrations when possible. Duplicate spectra were recorded for every concentration for quality assurance purposes. The ASC column is the accepted standard concentration which was assigned b y the chemical standard. The ASC values should be used for data analysis. Duplicate samples were obtained for each concentration. These spectra were developed following the Protocol for Extrative FTIR for Analysis of Gas Emissions . Refer to the FTIR TECHNOLOGY DEVELOPMENT Report for additional information regarding the these spectra.
EPA Reference Spectra Interferograms
Listed are the interferograms from which the EPA Reference Absorbance Spectra were created. Single beam spectra can be created from these interferograms by using the FTPROC program avalible on this site. The Background Interferograms are those interferograms recorded while the absorption cell was evacuated. The Data Interferograms are those interferograms recorded with the analyte present in the absorption cell. The CTS Interferograms are those associated with the recording of the absorption of the Calibration Transfer Standard gas. For more information on the recording of the interferograms please see the report FTIR TECHNOLOGY DEVELOPMENT. The file naming convention used on the interferograms is the same used on the EPA Refernce Absorbance Spectra
【地址】 http://www.epa.gov/ttn/emc/ftir/data.html
【名称】美国标准与技术研究院NIST原子光谱数据库(ASD)
【资源简介】
The Atomic Spectra Database (ASD) contains data for radiative transitions and energy levels in atoms and atomic ions. Data are included for observed transitions of 99 elements and energy levels of 52 elements. ASD contains data on about 900 spectra from about 1 ? (?ngstr?ms) to 200 μm (micrometers), with about 70,000 energy levels and 91,000 lines, 40,000 of which have transition probabilities listed. The most current NIST-evaluated data associated with each transition are integrated under a single listing.
【地址】 http://physics.nist.gov/cgi-bin/AtData/main_asd
【名称】小型光谱数据库下载Optical Databases Download Page
【资源简介】
Here you will find collections of spectra, each contained in SpecManager databases for optical spectroscopy.
Ludmila Tumanova's collection of quantitative IR (13 entries) and FT-IR (2 entries)
【地址】 http://www.acdlabs.com/download/db/uv_ir.html
【名称】ACD/Web Librarian环境下的色谱应用数据库
【资源简介】
The Public Chromatography Applications Database under ACD/Web Librarian contains applications provided by Agilent, Alltech, Eprogen (Eichrom), GL Sciences, Hamilton, Argonaut (Jones Chromatography), Polymer Laboratories, and Regis. The database can be searched by numerous chromatographic parameters, as well as by structure, substructure, and structural similarity. For example, if you work with a novel compound, you will be able to retrieve chromatographic applications that were successfully used to separate compounds with similar chemical structures. This structure-based search capability, combined with the high quality of data and total number of applications (1830 HPLC/GC separations), has proven to be an invaluable resource for chromatographers facing the challenge of new method development.
It's a FREE Service, but you must register first at I-Lab
【地址】 http://www2.acdlabs.com/ilab/
【名称】Atomic Line List (原子吸收、发射性能数据)
【资源简介】
This is a compilation of approximately 923,000 allowed, intercombination and forbidden atomic transitions with wavelengths in the range from 0.5 ? to 1000 μm. It's primary intention is to allow the identification of observed atomic absorption or emission features. The wavelengths in this list are all calculated from the difference between the energy of the upper and lower level of the transition. No attempt has been made to include observed wavelengths. Most of the atomic energy level data have been taken from the Atomic Spectra Database provided by the National Institute of Standards and Technology (NIST).
【地址】 http://www.pa.uky.edu/~peter/atomic/
平凡人
第2楼2008/10/08
【名称】ECDYBASE (The Ecdysone Handbook)
【资源简介】
The " Ecdysone Handbook " was originally created by René Lafont and Ian D. Wilson and published in 1992 by the Chromatographic Society (Nottingham, U.K.). Its aim was to provide general data on all natural ecdysteroids described so far. Each data sheet contained (whenever available) spectroscopic (UV, IR, MS and NMR) and chromatographic data together with a few selected general references. As the ecdysteroid family continued to increase, a second enlarged edition was published in 1996, but the number of compounds is still growing (more than 300 compounds were described at the onset of year 2000).
Owing to the limited number of people interested by such a Handbook, a printed version is no longer justified, and moreover the problem of updating content was a major one. This led to the idea of developing a new concept, making a proper use of modern communication tools. A decision was taken to transform the Handbook in a database made freely available on the web to anyone interested in ecdysteroids.
【地址】 http://ecdybase.org/
【名称】应用化学数据库
【资源简介】
碳-13核磁共振波谱数据库
碳-13核磁共振波谱数据库系统始建于1982年,它是国内第一个比较大型的碳-13 NMR谱图数据库系统,主要用于有机化合物结构的自动解析。数据类型包括各类有机化合物的碳-13 NMR谱图数据,如天然产物,金属有机化合物, 毒物等各类化合物。数据项包括化合物名称、分子式、化合物重量、化学位移、多重性、实验条件、相关的文献等。
稀土萃取数据库
稀土萃取数据库系统始建于1987年,主要用于稀土的分离。稀土萃取数据库的主要数据类型为:中性磷类萃取剂;胺类萃取剂;羧酸类萃取剂;无机酸的萃取。数据项包括萃取剂名称、分子式、被萃成分(金属元素和无机酸)、极性项、稀释剂、辅助配位体、参考文献等。
稀土物理化学性质数据库
稀土物理化学性质数据库系统始建于1987年,主要用于与稀土相关的材料的研究与设计。数据库中包括氧化物,卤化合物,硫化合物,金属间化合物等40余种化合物的熔点,沸点,生成热,熵,焓等多种物理化学性质。
化合物活性数据库
化合物活性数据库中包括化合物的CAS登录号,化合物名称,分子式,分子量,活性值等
【地址】 http://www.appchem.csdb.cn/
【名称】质谱:Mass Spectrometry Database,American Academy of Forensic Sciences
【资源简介】
This library is a "subset" of one that has been compiled over a period of many years by Dr. Graham Jones and colleagues in Edmonton, Alberta, Canada. Pure drug spectra, plus a few breakdown products and pure metabolite standards have been edited into a single library. The first version of this library contained about 1500 entries. A separate library of metabolites, endogenous compounds and artifacts is under construction, but may be 1-2 years from completion of the first draft (it's an incredibly time consuming process!!).
【检索途径】
The current library is aafsdrug.zip. Click on the file name to download. This file consists of the component files of this library, compressed with the utility pkzip, into a single "zip" file. This saves space and allows a shorter, easier download than if the individual uncompressed files were available. A list of entries can be downloaded separately as an MS Excel v. 4 spreadsheet file that can be viewed with most spreadsheet and many database programs.
Software Compatibility
Libraries made available by the committee primarily designed to be compatible with HP 5970/71/72/73 series instruments that have PC-based DOS/Windows ChemStation operating systems. See the Software Compatibility page for a fuller discussion and the availability of libraries translated for other mass spectrometers.
【地址】 http://www.ualberta.ca/~gjones/mslib.htm
【名称】SweeT-DB (糖类化合物数据库)
【资源简介】
Sweet-DB includes:
about 50,000 carbank entries
more than 22,000 carbohydrate structures
15,000 publications about 1,000 pubilcations collected via Auto-Sweet-DB
about 10,000 spatial representations generated with sweet.
【检索途径】
SweeT-DB is the main glycosciences data base which allows glycoscientists to find important data for the compound of interest in a compact and well-structured representation. Currently, reference data taken from CarbBank, which is linked to the NCBI PubMed service, NMR data taken from SugaBase , theoretically calculated MS-spectra and 3D coordinates generated with SWEET-II can be retrieved for a given carbohydrate (sub)structure.
Search is supported by formula, exact structure, author or fuzzy author, Fuzzy title, LinucsID, Classification, Composition and Peak Search, etc.
【地址】 http://www.dkfz-heidelberg.de/spec/sweetdb/
【名称】糖类(碳水化合物)拉曼谱图库SPECARB (Raman Spectra of Carbohydrates)
【资源简介】
SPECARB is an experimental database containing Raman spectra of carbohydrates. It is intended to contain solid state Raman spectra of carbohydrates from the monomers and their derivatives to complex polysaccharides. Unless otherwise stated, the spectra are sampled on a Perkin Elmer System 2000 interferometer using a Nd:YAG laser. To obtain comparable spectra they will be recorded using the following parameters
【地址】 http://newton.foodsci.kvl.dk/users/engelsen/specarb/specarb.html
平凡人
第3楼2008/10/08
【名称】Elemental Data Index (元素的物理数据)
【资源简介】
The Elemental Data Index provides access to the holdings of NIST Physics Laboratory online data organized by element.
【地址】 http://physics.nist.gov/PhysRefData/Elements/cover.html
【名称】eCrystals - Southampton (晶体结构数据共享库)
【资源简介】
The information contained within an entry in this archive is all the underlying data generated during the course of a structure determination from a single crystal x-ray diffraction experiment. This information is freely available and allows the reader to a) assess the validity of the dataset or b) repeat the experiment or c) use the data for further studies.
An individual entry consists of three parts:
Core bibliographic data, such as authors, affiliation and a number of chemical identifiers,
Data collection parameters that allow the reader to assess at a glance certain aspects of the crystallographic dataset,
Files available for download. These files are: visualisations of the raw data (.jpg), the raw data itself (.hkl), experimental conditions (.htm), outputs from stages of the structure determination (_xs.lst, _xl.lst & .res), the final structural result (.cif & .cml) and the validation report of the derived structure (_checkcif.htm).
This archive is running on GNU EPrints open archive software, a freely distributable archive system available from software.eprints.org.
【地址】 http://ecrystals.int.chem.soton.ac.uk/
【名称】FTNMR Spectra in NUTSTM Format
【资源简介】
The FTNMR FID archive (see below) lists a number of 13C, 1H, and APT free induction decay files in Nuts format (a Windows NMR off-line data processing program). Most of these files are also available on another page of the Archive in Felix for Windows format (another off-line NMR data processing program).
Compounds are listed according to increasing carbon number. All the FIDs presently listed below were collected on a 300 MHz spectrometer at Pacific Lutheran University.
【地址】 http://rainier.chem.plu.edu/nutsform.html
