zhaoyongqiang
第2楼2009/02/10
1 of 1 Result List | Refine Search
Format and Delivery OptionsView:Citation PDF Full Text (1.1MB) Delivery Options:
Citation DetailTitle:Synthesis and design of integrated-magnetic-circuit transformer for VRM application.
Authors:Chen, R.-T.1 rtchen@ipmce.ee.ntu.edu.tw
Chen, Y.-Y.1
Source:IEE Proceedings -- Electric Power Applications; May2006, Vol. 153 Issue 3, p369-378, 10p, 8 diagrams, 7 graphs
Document Type:Article
Subject Terms:ELECTRIC transformers
MAGNETIC circuits
CASCADE converters
TOPOLOGY
ELECTRIC circuits
NAICS/Industry Codes:334416 Electronic Coil, Transformer, and Other Inductor Manufacturing
335311 Power, Distribution, and Specialty Transformer Manufacturing
Abstract:The paper proposes an improved transformer with an integrated magnetic circuit of the push–pull converter. For high-power server-type applications, the push–pull forward converter has been proven to have significantly better performance than the buck converter. This topology also provides a built-in input filter, and thus a smooth input current. All the magnetic components are integrated in a single core. The simulation of integrated magnetic and magnetic-circuit analysis identifies the proposed transformer correctly. Comparison is given of experimental results of discrete and integrated transformers. [ABSTRACT FROM AUTHOR]
Copyright of IEE Proceedings -- Electric Power Applications is the property of Institution of Engineering & Technology and its content may not be copied or emailed to multiple sites or posted to a listserv without the copyright holder's express written permission. However, users may print, download, or email articles for individual use. This abstract may be abridged. No warranty is given about the accuracy of the copy. Users should refer to the original published version of the material for the full abstract. (Copyright applies to all Abstracts)
Author Affiliations:1National Taiwan University, Department of Electrical Engineering, Taipei, ROC
ISSN:1350-2352
DOI:10.1049/ip-epa:20050386
