原吸的试题,看看我做的对吗?
原子吸收光谱(AAS)
  • 1)When using flame atomic absorption spectroscopy, what is the purpose of adding releasing agents (i.e. lanthanum) to the standards and samples?
    a) To ensure the samples and the standards have similar surface tension and viscosity.
    b) To minimize atomization interferences.
    c) To increase the flame temperature.
    d) To reduce background interferences caused by the acetylene.
    e) To eliminate the need for probe rinsing.
    我选b
    2)When preparing standards for spectroscopic analysis of a sample, why is it important that the standards be similar in general composition (i.e. those constituents present in large quantity) to the unknown sample?
    a) To reduce any interferences caused by matrix effects.
    b) To reduce chemical inventories in the laboratory.
    c) To minimize the risk of using shelf-life expired standards.
    我选a
    3)What is(are) the purpose(s) of running calibration check samples at the end of an analysis run:
    a) To re-verify good instrument calibration.
    b) To evaluate instrument drift.
    c) To evaluate instrument reproducibility.
    d) All of the above
    e) Answers ‘B’ and ‘C’ only are correct
    不确定
    4)In alloy chemistry analysis, a trace element is defined as:
    a) The primary or matrix element in an alloy.
    b) A reference marker element used to verify detector calibration.
    c) A very low concentration residual element.
    我选C
  • 第2楼2005/06/12
    3总觉得都有道理,漂移和重复性也能评估吧?
  • 第3楼2005/06/12
    也是,但是就是校正检查发现飘逸了能怎么样?
    yaofei 发表:3总觉得都有道理,漂移和重复性也能评估吧?
  • 第4楼2005/06/12
    这是我同学的考题,化学分析简单极了,原吸我也马马虎虎,ICP的就不知道了,你能也帮我看看吗?
  • 第5楼2005/06/12
    等会抽空过去看看
    yaofei 发表:这是我同学的考题,化学分析简单极了,原吸我也马马虎虎,ICP的就不知道了,你能也帮我看看吗?
  • 第7楼2005/06/12
    全选也觉得不妥,重复性好像应该看重复几次的SD?
    难怪我的同学工资是我的n倍,人家不是学分析的考这个题目,而我学分析的还是稀里糊涂的
