poorlittle
第3楼2009/05/22
All Ghost Wipes are approved by AIHA. This revolutionary product eases sample preparation and analysis of surface lead or surface dust. The Ghost Wipe is a sturdy wiping material that holds together even on the roughest wiping surfaces. At the lab the Ghost Wipe readily and completely dissolves during the digestion process, providing more complete dispersion of analytes and more uniform recoveries. In addition, there is no messy fibrous material in the sample to clog the sample uptake capillary or nebulizer. Ghost Wipes meet all ASTM Designation E1792-96E specifications for sampling materials for lead in surface dust.
Wipes are 15cm x 15cm, pre-moistened with deionized water and come in individually sealed packets. Ghost wipes have been used successfully on alternative elements such as Ba, Be, Cr, Cu, Se, Zn and As. Pack of 500 wipes. Ghost Wipes are also available in packs of 1,000, SC4250.
from http://images.google.com.hk/imgres?imgurl=http://www.envexp.com/images/SC4210.JPG&imgrefurl=http://www.envexp.com/item/SC4210/GW/Ghost_Wipes__individual_sealed__15cm_x_15cm__500pk&usg=__6RGfX4rNIcjDMAnMTsn4jcMF-6o=&h=386&w=300&sz=20&hl=zh-TW&start=19&sig2=B6mOUd7f5epWIes-cS4fOQ&um=1&tbnid=mbjFwA98wK6SqM:&tbnh=123&tbnw=96&prev=/images%3Fq%3Dghost%2Bwipe%26hl%3Dzh-TW%26lr%3D%26sa%3DN%26um%3D1&ei=I6EWSs7JGaXy6gOMo7S4Cg
何当奇
第4楼2009/05/25
http://www.envexp.com/item/SC4250/GW/Ghost_Wipes__individual_sealed__15cm_x_15cm__1000pk
这个网址是相同的内容
看看这个
http://www.nowpublic.com/culture/christmas-season-marvel-recalls-curious-george-dolls
说的更加详细
