Recalibration Settings 重新校正设置: Average Response 平均响应:Adverage all calibrations 平均所有校正 Average Retention Time 平均保留时间:Floating Average New 75% ???
Calibration report options:校正报告选项: Printout of recalibration within a sequence:打印出一个序列内的重新校正 Calibration Table after recalibration 重新校正后的校正表 Normal Report after Recalibration 重新校正后的正常报告 If the sequence is done with bracketing: ??? Results of first cycle (ending previous bracket)???
