【求助】火焰原子发射法与火焰原子吸收法有什么不同?
  • 风之笑容
    2009/06/11
原子吸收光谱(AAS)
  • 能说一下它们的不同吗?经常使用这两种方法,但不知道它们本质有佳作区别?
  • chemistryren
    第1楼2009/06/11
    一个是发射光谱,一个是吸收光谱。
  • 风之笑容
    第3楼2009/06/11
    详细点可以吗?
    chemistryren 发表:一个是发射光谱,一个是吸收光谱。
  • yiye405
    第4楼2009/06/23
    我手里正好有点从PE AA400说明书中摘录的直接发给你:
    Emission vs. Absorption
    All modern Perkin-Elmer atomic absorption instruments are capable of
    measuring both atomic absorption and atomic emission. It is important
    for the operator to understand the processes that occur in each echnique.
    Every element has a specific number of electrons associated with its
    nucleus. The normal and most stable orbital configuration of an atom is
    known as the "ground state." If energy is applied to an atom, the energy
    will be absorbed and an outer electron will be promoted to a less stable
    configuration known as the "excited state." Since this state is unstable,
    the atom will immediately return to the "ground state," releasing light
    energy.
    Atomic Emission
    In atomic emission, the processes of excitation and decay shown in
    Figure 1 are both involved.
    Figure 1. Excitation and Decay
    The sample is subjected to a high-energy thermal environment in order
    to produce excited-state atoms. This environment can be provided by a
    flame or, more recently, a plasma. However, since the excited state is
    unstable, the atoms spontaneously return to the "ground state" and emit
    light. The emission spectrum of an element consists of a collection of
    emission wavelengths called emission lines because of the discrete nature of the emitted wavelengths. The intensity at an emission line will increase as the number of excited atoms of the element increases.
    Atomic Absorption
    The process of atomic absorption is illustrated in Figure 2.
    The "ground state" atom absorbs light energy of a specific wavelength
    as it enters the "excited state." As the number of atoms in the light path
    increases, the amount of light absorbed also increases. By measuring
    the amount of light absorbed, a quantitative determination of the
    amount of analyte can be made. The use of special light sources and
    careful selection of wavelengths allow the specific determination of
    individual elements.
    Atomic Emission vs. Atomic Absorption
    There are some basic differences between atomic emission and atomic
    absorption. Using atomic emission, the flame serves a dual purpose: it
    converts the sample aerosol into an atomic vapor and then thermally
    elevates the atoms to an excited state. When these atoms return to the
    ground state, they emit light which is detected by the instrument. The
    intensity of light emitted is related to the concentration of the element
    of interest in solution.
    In atomic absorption, the only function of the flame is to convert the
    sample aerosol into atomic vapor which can then absorb light from the
    primary light source (hollow cathode lamp or electrodeless discharge
    lamp).
    energy.
    Atomic Emission
    Atomic Absorption
    lamp).
  • 该帖子已被版主-夜市加3积分,加2经验;加分理由:感谢提供
  • djp1980
    第5楼2009/06/24
    楼上真是热心,全是打出来的,没用扫描,结果图却不能提供。
    版主应该给楼上加分,为了他乐于助人的精神!
    他还是今天注册的新用户。
    yiye405 发表:我手里正好有点从PE AA400说明书中摘录的直接发给你:
  • YJFH
    第6楼2009/06/24
    djp1980 发表:楼上真是热心,全是打出来的,没用扫描,结果图却不能提供。
    他还是今天注册的新用户。
  • 小李飞镖
    第7楼2009/06/25
    要是有中文版的就好了,英文啊,它认识我,我不认识它哦
    energy.
    Atomic Emission
    Atomic Absorption
    lamp).
    energy.
    Atomic Emission
    Atomic Absorption
    lamp).
