ciaclin
第1楼2009/08/19
GAO recommends the reverse phase ion-pair column, but general C18 is also OK for the assay of Alitame in our lab.
What is the Uv wavelength you used? Did you try 217 nm?
20mM NaH2PO4, pH 3.5 : MeCN = 9:1
hope it works.
pls see the attachment.Alitame
brucehom
第4楼2010/06/08
你好,按照您的做法,还是没有做出来,麻烦告知具体条件。您用的是什么检测器啊 ?
