DB-1701: (14%-Cyanopropyl-phenyl)-methylpolysiloxane Low/midpolarity Bonded and cross-linked Solvent rinsable
Test Mix: Capillary (0.18-0.32 mm I.D.) P/N: 200-0007 Megabore (0.45-0.53 mm I.D.) P/N: 200-0107
Certain thick film or thin film configurations require different test mixtures than those listed above. Please call J&W Technical Support for specific test mix information.
