小鸟飞翔
第3楼2009/12/07
LC System works with PDA, TUV, and ELS detectors.
February 1, 2006 - Waters® ACQUITY UPLC(TM) Ultra Performance LC(TM) (UPLC(TM)) is available with photodiode array (PDA), evaporative light scattering (ELS), and tunable ultraviolet (TUV) detectors for high-resolution analysis of compounds. Liquid chromatography (LC) system enables control over detector programming and monitoring from within Waters Empower(TM) chromatography software or MassLynx(TM) mass spectrometry software. PDA and TUV detectors support data rates to 80 Hz.
