几点建议供参考:
如果你的论文是测试多残留的,回答这几个要点:
1、目前SPE技术在净化时主要有2种形式:a直接通过,全收集型,b先吸附目标物,淋洗杂质,更换溶剂洗脱目标物
2、由于目标物种类繁多,性质差异大,使用b思路无法同时测试这么多项目,所以选用a思路
如果你的论文是测试单个农药或某一类性质相似的农药的,回答这几个要点:
2、目前农残测试主要净化方法还是a思路,b思路更多的使用在兽残领域和一些对净化效果要求特别高的农残项目上,本文选用a思路在操作上简便易行,净化效果已经可以满足要求,速度快,所以选用a思路
相关操作这篇文献供参考Pang G F,Liu Y M,Fan C L,et al.Analytical and Bioanalytical Chemistry,2006,384:1366.
还有一篇我的,呵呵
http://www.chrom-china.com/qikan/manage/wenzhang/sp080123.pdf
祝你好运
lyb041011048(lyb041011048) 发表:p. 5, l. 50-53: It is surprising that the SPE columns are equilibrated with acetonitrile, the same solvent as used for elution. It might be expected that the target compound is not very efficiently trapped on the SPE cartridge. Normally, the RP SPE material is activated with organic solvent then equilibrated with water or water/organic solvent (a weakly eluting medium). The latter allows for efficient retention of the sample compound.
这是审稿人的问题,这是做土壤时的问题,我用的是固相萃取小柱C18,乙腈活化,然后直接上样(乙腈提取的),最后用乙腈洗脱!审稿人说这不符合一般规程!请大家帮帮忙,看任何回复?或者有相关的参考文献提供!谢谢帮忙!!
