有水有渝
第4楼2010/05/09
2.2.2 梯度准确度的确认
2.2.2.1测试条件:
流动相:0.3%丙酮-水 检测波长:254nm
流速:1.000ml/min 柱温:30℃
2.2.2.2 测试方法:
按下表设置梯度洗脱程序,以两通(有阻尼管更好)代替色谱柱连接管路,先用超纯水冲洗系统,待基线平稳后开始执行梯度程序,画出梯度变化曲线。测定三次,取各梯度级高度的平均值,由曲线图测量100%B(C)梯度级平均高度计算各梯级实际体积%,每个梯级的理论体积%和实际体积%之差即为梯度准确度,以最大差值为梯度准确度误差。
梯度洗脱表
时间 | A通道(C通道):超纯水 | B通道(D通道):0.3%丙酮水溶液 |
0.00min | 100% | 0% |
3.00min | 100% | 0% |
6.00min | 0% | 100% |
9.00min | 0% | 100% |
9.01min | 20% | 80% |
12.00min | 20% | 80% |
12.01min | 40% | 60% |
15.00min | 40% | 60% |
15.01min | 60% | 40% |
18.00min | 60% | 40% |
18.01min | 80% | 20% |
21.00min | 80% | 20% |
21.01min | 100% | 0% |
24min | 100% | 0% |
柏坡
第6楼2010/05/09
那找来的这个资料啊? 有没有全套的发我一份,我正需要。
24min | 100% | 0% |
