symmacros
第1楼2010/06/30
参考:
This new autosampler features three-axis (x,y,z) motion and can
handle both liquid and headspace samples separately or simultaneously.
Two GCs installed side-by-side can share one TriPlus Autosampler with
asynchronous individual instrument start times; the sample type is easily
set with interchangeable dedicated turrets for headspace and liquid
samples. The autosampler system is compatible with the company's GC
line and accepts up to 300 vials, syringes from 5 to 250 mL, variable
needle lengths, multiple wash and waste vials, and headspace sample
temperatures up to 150 °C. The device can be controlled from a
dedicated Pocket PC or an external computer.
