【转帖】欧盟拟将六种SVHC物质列入REACH法规附件XIV(需授权物质清单)
  • 智慧的弟弟
    2010/07/07
REACH/EUP
  • 2010年6月30日,欧盟向WTO发布通报(通报号G/TBT/N/EEC/337),拟将以下六种物质列入REACH法规附件XIV(需授权物质清单)中,分别是:二甲苯麝香(musk xylene)、六溴环十二烷(HBCDD)、4,4’-二氨基二苯基甲烷(MDA)、邻苯二甲酸二(2-乙基己醇)酯(DEHP)、邻苯二甲酸丁卞酯(BBP)、邻苯二甲酸二丁酯(DBP)。这六种物质也是欧盟发布的第一批SVHC物质。而一旦被列入附件XIV中,则在“日落之日”前,每种物质需要申请授权方可投放欧盟市场。
    信息来源:技术壁垒资源网
  • 无名
    第1楼2010/07/07
    我看到的原文怎么是八个呢?
  • 无名
    第2楼2010/07/07
    ECHA's draft recommendation of priority substances for inclusion in the list of substances subject to authorisation
    The draft recommendation consists of an overview table describing the draft entries to be inserted in Annex XIV (this table is available here) and the substance specific specification documents providing the specification for each recommended entry in Annex XIV. These specification documents have been prepared on the basis of substance specific background documents developed by ECHA. (see table below for links to the specification documents and to the background documents).
    Interested parties are invited to submit comments on the draft recommendation and its reasoning by 30 September 2010, in particular on uses which should be exempted from the authorisation requirement. For commenting, the forms provided in the table below must be used.
    An outline of the general approach used to develop the draft recommendation is available below under "further information".
    Note: The consultation is subject to data privacy rules available below under "further information". In general ECHA may publish all comments and information received on its website. However interested parties can also submit confidential information, which will only be made available to ECHA, including its Committees, and the Commission. In that case a specification must be given by the submitting party as to why the information submitted is considered confidential. Detailed instructions on how to submit confidential information is provided in the commenting form.
    Substance identification Date of publication Deadline for commenting Link to the specification document Link to the background document Link to commenting form
    Substance name EC number CAS number
    2,4 – Dinitrotoluene (2,4-DNT) 204-450-0 121-14-2 01/07/2010 30/09/2010 Submit information
    Diarsenic pentaoxide 215-116-9 1303-28-2 01/07/2010 30/09/2010 Submit information
    Diarsenic trioxide 215-481-4 1327-53-3 01/07/2010 30/09/2010 Submit information
    Diisobutyl phthalate (DIBP) 201-553-2 84-69-5 01/07/2010 30/09/2010 Submit information
    Lead chromate 231-846-0 7758-97-6 01/07/2010 30/09/2010 Submit information
    Lead chromate molybdate sulfate red (C.I. Pigment Red 104) 235-759-9 12656-85-8 01/07/2010 30/09/2010 Submit information
    Lead sulfochromate yellow (C.I. Pigment Yellow 34) 215-693-7 1344-37-2 01/07/2010 30/09/2010 Submit information
    Tris (2-chloroethyl) phosphate (TCEP) 204-118-5 115-96-8 01/07/2010 30/09/2010 Submit information
  • 智慧的弟弟
    第3楼2010/07/09
    你的这个原文跟上面对不上哈
  • shuirukong
    第5楼2010/08/05
    还每天更新啊呵呵
  • 999youran
    第6楼2010/08/20
    谢谢楼主的分享了
