大概的意思是这样的:如果样品厚度超过5MM的话,这样会导致样品受热的不均匀,从而导致测得的玻璃化转变温度偏高。
cdjinjiancom 发表:7.4 For specimens of thickness greater than 5mm temperature nonuniformities of sufficient extent can develop within the specimen as to yield erroneously high values of the glass transition temperature using this test method.
请教各位这句话怎么理解? 谢谢!
