1. Particle Size (HPLC): can be reduced by as much as 50%.
2. Particle Size (gc): going from a larger to a smaller or a smaller to a larger (if it is the same “Range Ratio”, which is the diameter of the largest particle divided by the diameter of the smallest particle) particle size gc mesh support is acceptable, provided the chromatography meets the requirements of the system suitability
