poplar_yang
第2楼2010/12/15
对于后出峰的物质其保留时间肯定较长,那相对应的半高峰宽也会比先出来的峰要宽么?
理论上半高峰宽相同; but this depends on conditions - the similar analytes, with the same column conditions, the same carrier etc., yes; this is the base that we can calculate the percentage based on area, but mostly the actuality is not ideal.
