第1楼2005/12/20
酸;其盐类;其酯类;它们的盐类 PP-S1
2-Methylbuta-1,3-diene 2-甲基-1,3-丁二烯
2-Methylbutan-2-ol 2-甲基-2-丁醇
2-Methylpropan-2-ol (tert-Butyl alcohol) 2-甲基丙-2-醇(叔丁醇)
2-Phenylcinchoninic acid; 2-salicylcinchoninic acid; their salts; their esters 辛可芬(2-苯基金鸡宁酸);2-水杨□金鸡宁酸;它们的
盐类;它们的酯类 PP-S1,S3
2-Propen-1-ol (Allyl alcohol) 2-丙烯醇(丙烯醇)
3-(3,4-Dihydroxyphenyl)alanine;its salts 3-(3,4-二羟苯基)丙氨酸;其盐类 PP-S1,S3
3,3'-Dimethoxybenzidine (o-Dianisidine) 3,3*-二甲氧基联苯胺(邻联茴香胺)
3,5,5-Trimethylcyclohex-2-enone (Isophorone) 3,5,5-三甲基环己-2-烯酮 (异佛尔酮)
3.4-methylenedioxyethylamphetamine (MDEA) 3,4 -亚甲二氧基乙基安非他明 DD
3.4-methylenedioxymethamphetamine (MDMA) 3,4-亚甲二氧基甲基安非他明 DD
3.4-methylenedioxy-phenyl-2-propanone 3,4-亚甲二氧-苯基-2-丙酮
3-Di-n-butylaminomethyl-4,5,6-trihydroxyphthalide 3-正丁胺甲基-4,5,6-三羟基苯并□喃酮 PP
3-Heptanone (Ethyl butyl ketone) 3-庚酮(乙基丁基甲酮)
3-Hydroxymorphinan; its salts; its optical isomers; their salts, their esters and ethers; their salts 3-羟基吗啡喃;其盐类;其光学异构体;它们的盐类;它们的酯类及醚类;它们的盐类
PP-S1
3-Hydroxy-N-methylmorphinan; its salts; its optical isomers; their salts 3-羟基-N-甲基吗啡喃;其盐类;其光学异构体;它们的盐类
PP-S1
3-Hydroxy-N-phenacylmorphinan; its salts; its optical isomers; their salts; their esters and ethers; their salts 3-羟基-N-苯
甲□吗啡喃;其盐类;其光学异构体;它们的盐类;它们的酯类及醚类;它们的盐类 PP-S1
3-methyl-1-propanol 3-甲基丁醇
4,5-Benzopyrene 4,5-苯并芘
4-Aminodiphenyl and its salts 4-安基联苯及其盐
4-Cyano-1-methyl-4-phenylpiperidine 4-氰基-1-甲基-4-苯基□啶 DD
4-Cyano-1-methyl-4-phenylpiperidine; its salts 4-氰基-1-甲基-4-苯基□啶;其盐类 PP-S1
4-Cyano-2-dimethylamino-4,4-diphenylbutane 4-氰基-2-二甲胺基-4,4-二苯基丁烷 DD
4-Cyano-2-dimethylamino-4,4-diphenylbutane; its salts 4-氰基-2-二甲氨基-4,4-二苯基丁烷;其盐类 PP-S1
4-Epianhydrotetracycline 4-差向脱水四环素 AT
4-Epitetracycline 4-差向四环素 AT
4H-Cyclopenta [def]phenathrene 4H-环戊[def]菲
4-Methoxysalicyladehyde 4-甲氧基水杨酸
4-Methyl aminorex 4-甲基阿米雷司 DD
4-methylthioamphetamine 4-甲硫苯胺(4-甲硫安非他明) DD
4-Nitrodiphenyl 4-硝基联苯
4-Phenylpiperidine-4-carboxylic acid ethyl ester 4-苯基□啶-4-羧酸乙酯 DD
4-Phenylpiperidine-4-carboxylic acid ethyl ester; its salts 去甲□替啶;其盐类 PP-S1
5-Phenylhydantoin; its alkyl and aryl derivatives; their salts 5-苯基海因(5-苯基乙内□□);其烷其烷基与芬香基的衍生物;它们的盐类 PP-S1,S3
9,10-Dihydroanthracene 9,10-二氢□
Abciximab 阿昔单抗 PP-S1,S3
ABO grouping ABO 分型
absorbed dose 吸收剂量
absorption technique 吸收法
abundance ratio 含量比例
Acamprosate; its salts 阿坎酸;其盐类 PP-S1,S3
Acarbose; its salts 阿卡波糖;其盐类 PP-S1,S3
acaricide 杀虫剂
acceleration 加速;加速度
acceleration of gravity 重力加速度
acceleration scuff 加速擦印
Acceptable Daily Intake [ADI] 日容许摄入量
accessibility 可达性
accreditation 认可;认证
accumulated dose 累积剂量
Acebutolol; its salts 醋丁洛尔;其盐类 PP-S1,S3
Acemetacin, its salts 阿西美卒;其盐类 PP-S1,S3
Acenaphthene 二氢□
Acenaphthylene □
Acetaldehyde 乙醛
Acetanilide 乙□苯胺
Acetanilide; alkyl acetanilides 乙□苯胺;烷基乙□苯胺类 PP-S1,S2,S3
Acetazolamide 乙□唑胺
Acetic acid 醋酸(乙酸)
Acetic anhydride 醋酐;酸酐
Acetohexamide 醋磺己□ PP-S1,S3
Acetone 丙酮
Acetonitrile 乙□
Acetorphine; its salts; its esters and ethers; their salts 乙□氧戊甲吗啡;其盐类;其酯类及醚类;它们的盐类 PP-S1,S3
Acetrizoic acid 醋碘苯酸 PP-S1,S3
Acetyl chloride 乙□氯
Acetylcarbromal 乙□阿达林 PP-S1,S3
Acetyldihydrocodeine 醋氢可待因 DD
Acetyldihydrocodeine; its salts 醋氢可待因;其盐类 PP-S1,S3
Acetylene 乙炔
Aciclovir; its salts 阿昔洛韦;其盐类 PP-S1,S3
acid 酸
acid digestion 酸消化
acid phosphatase 酸性磷酸□
acid purification system 酸净化系统;酸再生系统
acid rain 酸雨
acid strength 酸强度
acid value 酸价
acidic 酸性
acidic dyes 酸性色料
acidosis 酸中毒
Acipimox; its salts 阿西莫司;其盐类 PP-S1,S3
Acitretin; its salts; its esters 阿维A;其盐类;其酯类 PP-S1,S3
Aclarubicin 阿柔比星 AT
Aconite, alkaloids of 乌头生物硷 PP
Aconitine 乌头□ PP
Acrivastine 阿伐斯汀 PP
Acrylic acid 丙烯酸
Acrylonitrile 丙烯□
Actinium [Ac] 锕
Actinomycin 放线菌素 AT
activated charcoal tube 活性碳采样管
activited carbon 活性碳
activity concentration 活度浓度
acute exposure 急性照射量(放射)
Adapalene; its salts; its esters 阿达帕林;其盐类;其酯类 PP-S1,S3
addiction 瘾;癖嗜
additives 添加物;添加剂(食物)
adhesion tester 粘性测试器
Adipidone 胆影酸
Administration Headquarters 行政总部
Administration Section 行政部
Adrenaline 肾上腺素
Adriamycin 阿霉素 AT
adsorption technique 吸附法
adulterant 搀杂物
adulteration 掺加;掺杂
aerosol 气溶胶;烟雾剂;浮质
Aesculetin 秦皮乙素
Aesculin 秦皮甲素
Aflatoxins 黄曲霉素
agarose gel □脂糖凝胶
agarose gel electrophoresis □脂糖凝胶电泳
agglutinates 凝集物
agglutination 凝集作用
Agricultural Pesticides Ordinance 除害剂条例
