第1楼2006/01/03
1 1525 BINARY HPLC PUMP
1525二元高压梯度泵
2 "KIT, 7725I MANUAL INJECTOR,1500 SERIES"
"7725i手动进样器,含 25uL进样注射器, 5, 20, 50, 200uL 定量管"
3 "REFRACTOMETER, 2414"
2414示差折光检测器
4 2487 2-CHANNEL UV/VIS DETECTOR
高灵敏度2487双通道可调紫外及可见波长检测器 (包括分析池)190-700nm
5 PEEK FTIGHT FITTING (ONE PIECE)
通用色谱柱接头
6 UNION
无死体积接头
7 COLUMN HEATER COMPARTMENT
柱温箱(环境温度 - 150oC)
8 "BREEZE ADD-ON SINGLE SYSTEM
1 x 716000527EN DOC, BREEZE PLAN S/W ID/INFO
1 x WAT045905 Symmetry?C18 5u 4.6x150mm Column
1 x 716000525 BREEZE SYSTEM QUICK INSTALL
1 x 750000159 BREEZE SYSTEM MAINTENANCE & TROUBLESHO
1 x 667000535 BREEZE, SOFTWARE ADD-ON
1 x WAT042887 PQ TEST MIX FOR ABSORB DET SYS"
BREEZE 色谱管理软件
9 WATERS STYRAGEL HR4 (THF) INT'L HAZA
凝胶色谱柱(有机相)
10 STYRAGEL HR5 THF INT'L HAZA
凝胶色谱柱(有机相)
11 STYRAGEL HR6 THF INT'L HAZA
凝胶色谱柱(有机相)
12 POLYSTY STD 4.3 X 104
凝胶色谱标样
13 POLYSTY STD 1.1 X 105
凝胶色谱标样
14 POLYSTY STD 1.8 X 105
凝胶色谱标样
15 POLYSTY STD 4.3 X 105
凝胶色谱标样
16 POLYSTY STD 1.3 X 106
凝胶色谱标样
17 SYMMETRYSHIELD RP18 5?M 3.9X150 COL
C18 色谱柱
18 XTERRA RP18 COLUMN 5?M 3.9X150MM
C18 色谱柱
