temperature of gas?how to explaining?
poplar_yang(poplar_yang) 发表:usually the lab temperature is stable at 18 -23 degree centigrade, so It is not the reason - temperature; if you find some pipe , for example the gas pipe is from outside, that could be the reason -temperature of gas.
