【转帖】UHPLC
  • UHPLC Survey Regional Distribution.
    Ultra high performance liquid chromatography (UHPLC) systems, also referred to as fast LCs, are designed to take full advantage of smaller particles (sub 2 μm), which yield higher resolution and increased sensitivity. Because of increased backpressure, UHPLC systems employ high-performance pumps that deliver up to 15,000 psi (1,000 bar) of pressure. Some systems solve the backpressure issue by elevating temperatures (via column oven), which lowers the viscosity of the mobile phase, allowing it to move faster through the column. UHPLC systems have been shown to provide analysis in less than 1 min and up to 40 times faster than conventional HPLC systems.
    The market for high performance liquid chromatography continues to be one of the most dynamic markets of the analytical instruments industry. Innovations in mass spectrometry helped to fuel growth for the HPLC market. But, in many cases, HPLC was somewhat of an afterthought and considered to be a mere inlet to MS. The introduction and development of UHPLC systems is forcing change in the liquid chromatography market as users re-evaluate existing and explore new applications.
    In a recent survey of nearly 500 UHPLC users, conducted by Strategic Directions International (SDi), the participants were asked to indicate the reasons for choosing UHPLC over standard HPLC or other types of liquid chromatography systems. Improved resolution was the most frequently mentioned response. However, when asked to indicate UHPLC drawbacks, expensive column price tag was frequently mentioned.
    The accompanying graph shows the regional distribution of respondents to the survey. The United States and Canada represented the largest segment of respondents, followed by Europe, Asia (China, Japan, India, Pacific Rim), and the rest of the world.
  • 该帖子已被版主-有水有渝加2积分,加2经验;加分理由:鼓励分享
  • pangey
    第1楼2011/01/21
    调查显示:分辨率高是用户选择UPLC的最主要原因;而昂贵的耗材是最大的缺点。
  • 阿三
    第2楼2011/01/23
    UHPLC替代HPLC是不是未来的趋势呢
  • baihu47
    第3楼2011/01/23
    UPLC将来技术成熟了,价格下降了,会慢慢将HPLC替代
  • redrumcha
    第4楼2011/01/24
    是好东西,不过现阶段还不会替代HPLC,也没有比较。
    阿三(junqiwudi) 发表:UHPLC替代HPLC是不是未来的趋势呢
  • johne0212
    第5楼2011/01/24
    首先感谢楼主给分享这么一个Survey,但是我感觉翻译这篇文献的时候还是考虑好用词的问题,谨慎一点好,"分辨率"一般是我们判断质谱性能的一个参数,在这篇文献里作者应该是说分离度高应该好一点.
    另外,我感觉就现在我们接触的uplc和UHPLC的用户来说,灵敏度增高和分析效率的增加是它的主要优点.
    pangey(pangey) 发表:调查显示:分辨率高是用户选择UPLC的最主要原因;而昂贵的耗材是最大的缺点。
  • 该帖子已被版主-有水有渝加2积分,加2经验;加分理由:评论奖励
  • zhaohua8011
    第6楼2011/01/25
    相对于已经成熟的HPLC,UPLC是发展趋势,但目前成本过高!
