hello everybody: if you were always working hard,practivly sloved problem and found solutions.one day ,you wanted to decrease the cost from phosphating.and then you had some problem.so ,the leader just said some words.the OP wanted to call your names because the experiment affecting prodution. is it wrong? do you fell wronged?what will you do?
enn,thanks ,i know what should i do.actually the mould was damaged by the samples which were producted in my way.so it's normal that they hate me.but ,i know the limited at least.so i think it was worth.i will make it to the end!thanks everybody.
