【求助】请问,该如何排除液相检测器中的气泡呢?
  • 如题,谢谢!!!
  • zlignc
    第1楼2011/02/26
    1. Create some back pressure after the dectector and suddenly release the pressure. Repeat this several time.
    2. Flow pure organic solvent with how flow rate through your flow cell.
    3. Use syringe to push methanol through the the flow cell.
    You can try the above methods. You can also take out the flow cell to check the presence of bubble.
  • 1818
    第2楼2011/02/26
    打开旁通阀,以高流速冲!!
  • wsy18
    第3楼2011/02/27
    也可以冲洗时在废液输出口加点背压。
