雾非雾
第1楼2011/03/07
Mini-Luke 和QuEChERS方法的对比
Prepare samples more quickly, easily, and cost-effectively with QuEChERS.
Mini-Luke or Modified Luke Method | QuEChERS | Savings with QuEChERS | |
Estimated time to process 6 samples (min.) | 120 | 30 | 4x faster |
Solvent used (mL) | 60-90 | 10 | 6-9x less solvent |
Chlorinated waste (mL) | 20-30 | 0 | Safer, cheaper, greener |
Glassware/Specialized equipment | capacity for 200mL, quartz wool, funnel, water bath or evaporator | none | Ready-to-use |
