feixiong5134
第1楼2006/01/01
5.利用超分子结构维持化学不稳定物质的完整性。同时保存包含产物释放的化学反应
中的催化位点,
Harness supramolecular constructs to preserve the integrity of chemi-
cally labile species while conserving sites for the catalysis of chem-
ical reactions including product release.
6.用平行的自动的合成方法或组合试探反应来逐步地提高化学反应的转化率。
Use parallel automated synthesis or combinatorial trial-and error
reactions to improve on a chemical transformation in an evolutionary
manner.
7.对参加反应的两个分子接近时的取向进行控制。
Control the direction and orientation of the approach of one molecule
reacting with another.
8.理解分子的内部运动,从而可以在适当的时刻用一个电磁脉冲去打断分子中一个选
定的键(选键化学)。
Understand the internal motions of molecules so that,with appropriate
timing,a pulse of electromagnetic energy can be used to dissociate
specifically a chosen bond in the molecule
feixiong5134
第2楼2006/01/01
9.理解分子内部相互作用的结构和动力学,以便于我们能对分子聚集体进行预测和控
制。
Understand the structure and dynamics of inter-molecular interactions
so that the properties of molecular collections can be predicted and
controlled.
10.设计反应物和反应途径以打断原先认为是惰性的化学键。
Devise reagents and pathways for breaking into chemical bonds previou-
sly considered to be inert.
11.寻找将丰富的自然物质转化为有用的化学小分子结构单元的方法以及相反的方法
Find the means for converting naturally abundant substances into
chemically useful small-molecule building blocks and vice versa.
12.发展非溶液反应技术,
Develop the art of conducting chemical reactionswithout solvents.
13.合成能够只对分子的一部分进行选择性反应的化合物,从而不必在反应前先对分
子中不想改变的活性位点进行保护并在反应后去保护。
Create reagents that chemically modify a portion of a molecle without
protecting. and later having to deprotect, other reactive sites on
the molecule that we do not want to modify.
14.寻找不使用也不会产生有害物质而是利用可再生资源的反应途径并用它们来合成
化学产物.
Create chemical products and processes that do notrequire the use or
generation of hazardous substances and that use renewable resources.
15.认识和利用尺寸介于分子和固态之间(1-100nm)的化合物的性质。
Understand and harness the properties of compounds of intermediate(1-
100nm) size between the mo1ecular and solid state.
feixiong5134
第3楼2006/01/01
16.对单个孤立分子性质的比较,并与多个此类分子和不同溶液中的集体性质进行比较
Investigate the chemistry of single isolated molecules and compare the
properties with those of an ensemble of such molecules and in various
solvents.
17.合成能自组装成包括固态在内的具有比分子 聚集体性质优越的超分子结构。
Create molecules that self-assemble into supramolecular structures
including solids,the properties of which surpass those of the
molecular collection.
18.研究如何用任意组分的分子来生成晶态物质 以及通过掺入客体物质以提高其物理
和化学性能。
Learn how to grow crystalline solids of molecules of any composition
and to incorporate guests into these crystals to enhance their physi-
cal and chemical properties.
19.发现由化学元素和基本粒子通过以前没有发 现的组合方式组成的特殊的化合物。
Discover unusual compositions of matter comprising chemical elements
and fundamental particles in combinations not previously encountered.
20.掌握笼状物化学,以便能够按照人们的愿望 通过化学、磁场或电场的方式使囚禁
在气体、液体或 固体宿主中的客体分子被释放出来。
Master the chemistry of caged species,releasing at will a guest entr-
apped in an appropriatehost in the gas,solution.or solid state by
introducing a chemical,magnetlc or electric field.
21.理解和应用多原子分子自由基的化学性质、 能量学和光谱知识。
Understand and use the chemistry energetics and spectroscopy of poly-
atomic radicals.
22.发展关于化学键和反应的新的理论方法,并且通过真实的化学体系来检验它们。
Evolve new theoretical approaches to understand chemical bonding and
reactions and to test these.
