feixiong5134
第1楼2006/01/02
2-Furaldehyde (Furfural) 糠醛(□喃甲醛)
2-Heptanone (Methyl n-amyl ketone) 2-庚酮(甲基正戊基甲酮)
2-Hexanone (Methyl n-butyl ketone) 2-己酮 (甲基正丁基甲酮)
2-Methoxyethanol [EGME] 2-甲氧基乙醇
2-Methoxyethyl acetate [EGMEA] 醋酸-2-甲氧基乙酯
2-methyl-1-propanol 2-甲基丁醇
2-Methyl-3-morpholino-1,1-diphenylpropanecarboxylic acid 2-甲基-3-吗□酮-1,1-二苯基丙烷羧酸
2-Methyl-3-morpholino-1,1-diphenyl-propanecarboxylic acid 2-甲基-3-吗□酮-1,1-二苯基丙烷羧酸 DD
2-Methyl-3-morpholino-1,1-diphenylpropanecarboxylic acid; its salts; its esters; their salts 2-甲基-3-吗啡酮-1,1-二苯基丙烷羧
酸;其盐类;其酯类;它们的盐类 PP-S1
2-Methylbuta-1,3-diene 2-甲基-1,3-丁二烯
2-Methylbutan-2-ol 2-甲基-2-丁醇
2-Methylpropan-2-ol (tert-Butyl alcohol) 2-甲基丙-2-醇(叔丁醇)
2-Phenylcinchoninic acid; 2-salicylcinchoninic acid; their salts; their esters 辛可芬(2-苯基金鸡宁酸);2-水杨□金鸡宁酸;它们的
盐类;它们的酯类 PP-S1,S3
2-Propen-1-ol (Allyl alcohol) 2-丙烯醇(丙烯醇)
3-(3,4-Dihydroxyphenyl)alanine;its salts 3-(3,4-二羟苯基)丙氨酸;其盐类 PP-S1,S3
3,3'-Dimethoxybenzidine (o-Dianisidine) 3,3*-二甲氧基联苯胺(邻联茴香胺)
3,5,5-Trimethylcyclohex-2-enone (Isophorone) 3,5,5-三甲基环己-2-烯酮 (异佛尔酮)
3.4-methylenedioxyethylamphetamine (MDEA) 3,4 -亚甲二氧基乙基安非他明 DD
3.4-methylenedioxymethamphetamine (MDMA) 3,4-亚甲二氧基甲基安非他明 DD
3.4-methylenedioxy-phenyl-2-propanone 3,4-亚甲二氧-苯基-2-丙酮
3-Di-n-butylaminomethyl-4,5,6-trihydroxyphthalide 3-正丁胺甲基-4,5,6-三羟基苯并□喃酮 PP
3-Heptanone (Ethyl butyl ketone) 3-庚酮(乙基丁基甲酮)
3-Hydroxymorphinan; its salts; its optical isomers; their salts, their esters and ethers; their salts 3-羟基吗啡喃;其盐类;其
光学异构体;它们的盐类;它们的酯类及醚类;它们的盐类 PP-S1
3-Hydroxy-N-methylmorphinan; its salts; its optical isomers; their salts 3-羟基-N-甲基吗啡喃;其盐类;其光学异构体;它们的盐类
PP-S1
3-Hydroxy-N-phenacylmorphinan; its salts; its optical isomers; their salts; their esters and ethers; their salts 3-羟基-N-苯
feixiong5134
第2楼2006/01/02
甲□吗啡喃;其盐类;其光学异构体;它们的盐类;它们的酯类及醚类;它们的盐类 PP-S1
3-methyl-1-propanol 3-甲基丁醇
4,5-Benzopyrene 4,5-苯并芘
4-Aminodiphenyl and its salts 4-安基联苯及其盐
4-Cyano-1-methyl-4-phenylpiperidine 4-氰基-1-甲基-4-苯基□啶 DD
4-Cyano-1-methyl-4-phenylpiperidine; its salts 4-氰基-1-甲基-4-苯基□啶;其盐类 PP-S1
4-Cyano-2-dimethylamino-4,4-diphenylbutane 4-氰基-2-二甲胺基-4,4-二苯基丁烷 DD
4-Cyano-2-dimethylamino-4,4-diphenylbutane; its salts 4-氰基-2-二甲氨基-4,4-二苯基丁烷;其盐类 PP-S1
4-Epianhydrotetracycline 4-差向脱水四环素 AT
4-Epitetracycline 4-差向四环素 AT
4H-Cyclopenta [def]phenathrene 4H-环戊[def]菲
4-Methoxysalicyladehyde 4-甲氧基水杨酸
4-Methyl aminorex 4-甲基阿米雷司 DD
4-methylthioamphetamine 4-甲硫苯胺(4-甲硫安非他明) DD
4-Nitrodiphenyl 4-硝基联苯
4-Phenylpiperidine-4-carboxylic acid ethyl ester 4-苯基□啶-4-羧酸乙酯 DD
4-Phenylpiperidine-4-carboxylic acid ethyl ester; its salts 去甲□替啶;其盐类 PP-S1
5-Phenylhydantoin; its alkyl and aryl derivatives; their salts 5-苯基海因(5-苯基乙内□□);其烷其烷基与芬香基的衍生物;它们的盐类 PP-S1,S3
9,10-Dihydroanthracene 9,10-二氢□
Abciximab 阿昔单抗 PP-S1,S3
ABO grouping ABO 分型
absorbed dose 吸收剂量
absorption technique 吸收法
abundance ratio 含量比例
Acamprosate; its salts 阿坎酸;其盐类 PP-S1,S3
Acarbose; its salts 阿卡波糖;其盐类 PP-S1,S3
acaricide 刹螨剂
acceleration 加速;加速度
acceleration of gravity 重力加速度
acceleration scuff 加速擦印
Acceptable Daily Intake [ADI] 日容许摄入量
accessibility 可达性
accreditation 认可;认证
accumulated dose 累积剂量
Acebutolol; its salts 醋丁洛尔;其盐类 PP-S1,S3
Acemetacin, its salts 阿西美卒;其盐类 PP-S1,S3
Acenaphthene 二氢□
feixiong5134
第3楼2006/01/02
Acenaphthylene □
Acetaldehyde 乙醛
Acetanilide 乙□苯胺
Acetanilide; alkyl acetanilides 乙□苯胺;烷基乙□苯胺类 PP-S1,S2,S3
Acetazolamide 乙□唑胺
Acetic acid 醋酸(乙酸)
Acetic anhydride 醋酐;酸酐
Acetohexamide 醋磺己□ PP-S1,S3
Acetone 丙酮
Acetonitrile 乙□
Acetorphine; its salts; its esters and ethers; their salts 乙□氧戊甲吗啡;其盐类;其酯类及醚类;它们的盐类 PP-S1,S3
Acetrizoic acid 醋碘苯酸 PP-S1,S3
Acetyl chloride 乙□氯
Acetylcarbromal 乙□阿达林 PP-S1,S3
Acetyldihydrocodeine 醋氢可待因 DD
Acetyldihydrocodeine; its salts 醋氢可待因;其盐类 PP-S1,S3
Acetylene 乙炔
Aciclovir; its salts 阿昔洛韦;其盐类 PP-S1,S3
acid 酸
acid digestion 酸消化
acid phosphatase 酸性磷酸□
acid purification system 酸净化系统;酸再生系统
acid rain 酸雨
acid strength 酸强度
acid value 酸价
acidic 酸性
acidic dyes 酸性色料
acidosis 酸中毒
Acipimox; its salts 阿西莫司;其盐类 PP-S1,S3
Acitretin; its salts; its esters 阿维A;其盐类;其酯类 PP-S1,S3
Aclarubicin 阿柔比星 AT
Aconite, alkaloids of 乌头生物硷 PP
Aconitine 乌头□ PP
Acrivastine 阿伐斯汀 PP
Acrylic acid 丙烯酸
Acrylonitrile 丙烯□
Actinium [Ac] 锕
Actinomycin 放线菌素 AT
activated charcoal tube 活性碳采样管
activited carbon 活性碳
activity concentration 活度浓度
acute exposure 急性照射量(放射)
Adapalene; its salts; its esters 阿达帕林;其盐类;其酯类 PP-S1,S3
feixiong5134
第4楼2006/01/02
addiction 瘾;癖嗜
additives 添加物;添加剂(食物)
adhesion tester 粘性测试器
Adipidone 胆影酸
Administration Headquarters 行政总部
Administration Section 行政部
Adrenaline 肾上腺素
Adriamycin 阿霉素 AT
adsorption technique 吸附法
adulterant 搀杂物
adulteration 掺加;掺杂
aerosol 气溶胶;烟雾剂;浮质
Aesculetin 秦皮乙素
Aesculin 秦皮甲素
Aflatoxins 黄曲霉素
agarose gel □脂糖凝胶
agarose gel electrophoresis □脂糖凝胶电泳
agglutinates 凝集物
agglutination 凝集作用
Agricultural Pesticides Ordinance 除害剂条例
agrochemical 农用化学品
Air Chemistry Section 空气化验组
air particulate 空气粒子;大气粒子
Air Pollution Control Ordinance 空气污染管制条例
airborne particle counter 空气粒子计数器
Alclofenac; its complexes 阿氯芬酸;其复合物 PP-S1,S3
alcohol 酒精
Alcohol, denatured 变性醇(食物)
alcoholic strength 酒精度
Alcuronium; its salts 双烯丙毒马钱硷类;其盐类 PP-S1,S3
Aldesleukin 阿地白介素 PP-S1,S3
Aldrin 氯甲桥□
Alendronic acid; its salts 阿仑膦酸;其盐类 PP-S1,S3
Alfuzosin; its salts 阿夫唑秦;其盐类 PP-S1,S3
alignment of radical 根团的排列
Alizapride; its salts 阿立必利;其盐类 PP-S1,S3
alkaline phosphatase □性磷酸□
alkaloid 生物□
alleged father 疑父
allele 等位基因
allele frequency 等位基因频率
allergy 过敏反应
Allopurinol 别嘌醇 PP
allyl alcohol 丙烯醇
feixiong5134
第5楼2006/01/02
Allylisopropylacetylurea 烯丙异丙乙□□ PP-S1,S3
Allylprodine; its salts 烯丙罗定;其盐类 PP-S1
Almitrine; its salts 阿米三□;其盐类 PP-S1,S3
Aloe-emodin 芦荟大黄素
Aloin 芦荟□
alpha particle 阿尔法粒子;氦原子核
alpha spectrometry 阿尔法谱法
alpha, alpha-Dichlorotoluene α,α-二氯甲苯
alpha,alpha-Dimethylbenzyl hydroperoxide α,α-二甲□基过氧化氢
Alphacetylmethadol α-乙□美沙多 DD
Alphacetylmethadol (-Acetylmethadol) α-乙□美沙多 DD
Alphadolone; its esters 阿法多龙;其酯类 PP-S1,S3
alpha-foetal protein [AFP] 甲种胎儿蛋白
alpha-Meprodine; its salts 阿法美罗定;其盐类 PP-S1
Alphamethadol α-美沙多 DD
Alpha-methadol α-美沙多 DD
alpha-Naphthylacetic acid; its salts 阿法□乙酸;其盐类 PP-S1,S3
alpha-Prodine; its salts 阿法罗定;其盐类 PP-S1
Alphaxalone 阿法沙龙 PP-S1,S3
Alpinetin 山姜素
Alprazolam 阿普唑仑 DD
Alprenolol; its salts 阿普洛尔;其盐类 PP-S1,S3
Alprostadil 前列地尔 PP-S1,S3
Alteplase 纤维蛋白溶□原活化剂 PP-S1,S3
altered document 经涂改的文件
Alufibrate 祛脂酸铝 PP-S1,S3
Aluminium [Al] 铝
Amantadine; its salts 金刚胺;其盐类 PP-S1,S3
ambient air 环境空气
ambient dose 环境剂量
American Conference of Governmental Industrial Hygienists [ACGIH] 美国政府工业卫生专家协会
American Industrial Hygiene Association [AIHA] 美国工业卫生协会
American Society for Testing and Materials [ASTM] 美国试验与材料协会
Americium [Am] □
Amfepramone 二乙胺苯丙酮 DD
Amidopyrine; its salts 氨基比林;其盐类 PP-S1,S3
Amifostine; its salts 氨磷汀;其盐类 PP-S1,S3
Amikacin 丁胺卡那霉素 AT
Amiloride; its salts 氨基比林;其盐类 PP-S1,S3
Amineptine; its salts 阿米庚酸;其盐类 PP-S1,S3
Amino-alcohols esterified with benzoic acid, phenylacetic acid, phenylpropionic acid, cinnamic acid or the derivatives of these acids; their salts (except procaine when in a preparation containing any substance to which the Antibiotics Ordinance for the time being applies) 氨基醇 (经苯甲酸,苯乙酸,苯丙酸,肉桂酸或上述各酸的衍生物酯化者); 它们的盐类 (但在含有《抗生素绦例》(第137章)当其时适用的物质的制剂中的普鲁卡因除外) PP-S2 (Procaine)
feixiong5134
第6楼2006/01/02
Aminoglutethimide 氨鲁米特 PP-S1,S3
Aminophylline; its salts 氨茶硷;其盐类 PP
Aminopterin; its derivatives 氨蝶呤;其衍生物 PP-S1,S3
Aminorex 阿米雷司 DD
Aminorex; its salts 阿米雷司;其盐类 PP-S1,S3
Amiodarone; its salts 胺碘酮;其盐类 PP-S1,S3
Amitriptyline; its salts 阿米替林;其盐类 PP-S1,S3
Amlodipine; its salts 氨氯地平;其盐类 PP-S1,S3
Ammonia 氨
Ammonia-N 氨-氮
Ammonium dichromate 重铬酸铵
Ammonium fluorosilicate 氟硅酸铵
Ammonium Glycyrrhizinate 甘草酸单铵盐
Amosite 铁石棉;棕石棉
Amoxicillin 羟氨□青霉素 AT
Amphetamine 安非他明 DD
Amphomycin 安福霉素 AT
Amphotericin 两性霉素 AT
Amphotericin B 两性霉素 B AT
Ampicillin trihydrate 氨□青霉素三水物 AT
amplification 扩增
amplifier 放大器
Amrinone 氨力农 PP-S1,S3
Amsacrine; its salts 安□啶;其盐类 PP-S1,S3
Amyl alcohol, mixed isomers, with the exception of tert-pentanol 戊醇,异构体混合物,叔戊醇除外
Amyl nitrite 亚硝酸异戊酯 PP
amylase 淀粉□
Amylene hydrate 水合戊烯 PP-S1,S3
analeptic 回苏剂
analgesic 止痛剂
Analgin 安乃近
analogue-to-digital converter 模拟-数码变换器
Analytical and Advisory Services Division 分析及谘询事务部
analytical column 分析柱
Analytical Methods Manual (AMM) 分析方法手册
Analytical Reagent [AR] 分析纯
anaphylactic shock 过敏性休克
Anastrozole; its salts 阿那曲唑;其盐类 PP-S1,S3
Androgenic, oestrogenic and progestational substances 雄激素;雌激素与孕激素物质 PP-S1,S3
Andrographolide 穿心莲内酯
anemometer 风速计
anesthetic 麻醉剂
aneurysm 动脉瘤
angina pectoris 心绞痛
Anhydrotetracycline 脱水四环素 AT
Anileridine; its salts 阿尼利定;其盐类 PP-S1
Aniline and homologues 苯胺及其同系物
Animals and Plants (Protection of Endangered Species) Ordinance 动植物(濒临绝种生物保护) 条例
anion 阴离子
anionic surfactants 阴离子洗涤剂
Anisic acid 茴香酸
Anisodamine hydrobromide 氢溴酸山茛菪硷
Anistreplase; its salts 茴香□化纤溶□原溶栓□活化剂复合物 PP-S1,S3
anneal 退火(冶金)
annihilation 湮没
annual limit of intake [ALI] 年吸入量限值;年撮入量限值
anode 阳极;正极
anorexia 厌食;无胃口
antacid 抗酸剂
Antazoline 安他唑林 PP-S1,S3
ante-mortem 死前
anthelmintic 抗蠕虫剂
Anthracene □
anthranilic acid 邻氨苯碌甲酸
antibiotic 抗生素;抗菌素
Antibiotics Ordinance 抗生素条例
antibody 抗体
anticholinergic 抗胆□的
anticoagulant 抗凝血剂
anticonvulsant 抗抽搐剂;抗痉挛剂
antidepressant 抗抑制剂;抗镇抑剂
antiemetic 止吐(呕)剂
antihistamine 抗组织胺剂
Antimony [Sb] 锑
Antimony pentachloride 五氯化锑
Antimony trichloride 三氯化锑
Antimony, chlorides of; organic compounds of; antimonates; antimonites 锑盐的氯化物;锑的有机化合物;锑酸盐;亚锑酸盐 PP-S1,S2
antioxidants 抗氧化剂
antipruritic 止痒剂
antipyretic 退热剂
feixiong5134
第7楼2006/01/02
Antipyrine 安替比林
antiserum 抗血清
Antithymocyte Immunoglobulin 抗胸腺细胞免疫球蛋白 PP-S1,S3
antitussive 镇咳剂
anvil 砧子
AOAC Official Method 公职分析化学工作者协会法定方法
apnoea 呼吸暂停
Apomorphine; its salts; its quaternary compounds 阿扑吗啡;其盐类;其四级化合物 PP-S1,S3
Aprindine; its salts 安博律定;其盐类 PP-S1,S3
Aramid 芳族聚□胺
Argon [Ar] 氩
Argon Ion Laser 氩离子激光器
Aristolochic Acid 马兜铃酸
Aroclor 亚老哥尔
arrhythmia 心律失常
Arsenic [As] 砷
Arsenic and soluble compounds 砷及其可溶化合物
Arsenical substances, the following: halides of arsenic; organic compounds of arsenic; oxides of arsenic; sulphides of arsenic; arsenates; arsenites; thioarsenates 含砷物贸如下;砷的卤代物;砷的有机化合物;砷的氧化物;砷的硫化物;砷酸盐;亚砷酸盐;硫代砷酸盐 PP-S1,S2
Arsine 胂(砷化氢)
articulated vehicle 拖挂车;连挂车
artificial colouring matter 人造色料
artificial sweetener 人造甜味素
as low as reasonably achievable [ALARA] 可合理达到的尽可能低的水平
Asbestos 石棉
Asbestos - Amosite 铁石棉;棕石棉
Asbestos - Chrysotile 温石棉;白石棉
Asbestos - Crocidolite 青石棉;蓝石棉
Asbestos Containing Materials [ACM] 含石棉物品
Asbestosis 石棉肺
ash content 灰分
ashing 灰化
Asphalt (petroleum) fumes 沥青(石油)烟雾
assay 定量;含量测定
assay pliers 试样钳
Assistant Departmental Secretary 助理部门秘书
Assistant Government Chemist 助理政府化验师
assisted signature 辅助签名(文件)
Association of Official Agricultural Chemists 政府农业化学家协会
Association of Official Analytical Chemists [AOAC] 公职分析化学工作者协会
Astatine [At] □
Astemizole 阿司米唑 PP-S1,S3
Astragaloside IV 黄蓍甲□
Atenolol 阿替洛尔 PP-S1, S3
Atenolol; its salts 阿替洛尔;其盐类 PP-S1,S3
atheroma 粉瘤
Atmospheric Pressure Chemical Ionization [APCI] 大气压化学电离
Atomic Absorption Spectrometer [AAS] 原子吸收分光光谱仪
Atomic Absorption Spectrometry : Electrothermal 电热原子吸收分光光谱法
Atomic Absorption Spectrometry : Flame 火焰原子吸收分光光谱法
Atomic Absorption Spectrometry : Furnace 石墨原子吸收分光光谱法
atomic number 原子序数
Atorvastatin; its salts 阿伐他汀;其盐类 PP-S1,S3
Atovaquone 阿托伐□ PP-S1,S3
Atracurium Besylate 阿曲库铵苯磺酸盐 PP-S1,S3
Atropine 阿托品 PP
Atropine sulphate 硫酸阿托品 PP
Auger electron 俄歇电子
Auranofin 金诺芬 PP-S1,S3
autoclave 消毒器
automated fibre detection 自动纤维检测
Automated Solid-Phase Extraction Clean-up 自动固相萃取净化;自动固相提取净化
automatic sampler 自动取样器;自动进样器
automatic titrator 自动滴定器
automatic weight variation system 自动化重量差异测试仪
autopsy 尸体解剖
autoradiograph 放射自显影片
autoradiography 放射自显影术
averted dose 可避免剂量
awl (ginlet) 手锉钻
Azacyclonol; its salts 阿扎环醇;其盐类 PP-S1,S3
Azapropazone 阿扎丙宗 PP-S1,S3
Azaserine 偶氮丝氨酸 AT
Azauridine; its derivatives 氮尿□其衍生物 PP-S1,S3
Azelastine 氮□斯汀 PP
Aziridine; its derivatives 氮丙啶;其衍生物 PP-S1,S3
Azobenzene 偶氮苯
azo-dye 偶氮染料
babies dummy 婴儿假奶咀
Bacitracin 杆菌□ AT
Backscatter Electron Detector 背散射电子检测器
Baclofen 巴氯芬 PP-S1,S3
Baicalin 黄芩□
feixiong5134
第8楼2006/01/02
balance 天秤
Bambuterol; its salts 班布特罗;其盐类 PP-S1,S3
band width 带宽
Barbitone 巴比妥 DD
barbiturate 巴比妥酸盐 PP-S1, S3
Barbituric acid; its salts; its derivatives; their salts; any compound with any substance falling within this item 巴比妥酸;其盐类;其衍生物;它们的盐类;含有任何属此项范围内的物质的化合物 PP-S1,S2,S3
Barium [Ba] 钡
Barium peroxide 过氧化钡
Barium, soluble compound 钡,可溶化合物
base □;基
base metal 贱金属
base pair □基对
baseline 基线;基准线
basic □性
basic dyes □性色料
Basiliximab; its salts 巴利昔单抗;其盐类 PP-S1,S3
Becke line 贝克线
Beclomethasone dipropionate 丙酸倍氯米松 PP-S1, S3
Becquerel 贝可
Befunolol; its salts 苯□洛尔;其盐类 PP-S1,S3
Belladonna, alkaloids of 颠茄生物硷 PP
Benactyzine; its salts 贝那替秦;其盐类 PP-S1,S3
Benazepril; its salts 贝那普利;其盐类 PP-S1,S3
Bendrofluazide □氟□□ PP-S1, S3
Benoxaprofen; its salts 苯恶洛芬;其盐类 PP-S1,S3
Benserazide; its salts □丝胼;其盐类 PP-S1,S3
Benzaldehyde 苯甲醛
Benzene 苯
Benzene synthesis 苯合成法
Benzethidine; its salts □替啶;其盐类 PP-S1
Benzhexol hydrochloride 盐酸苯海索 PP-S1, S3
Benzhexol; its salts 苯海素;其盐类 PP-S1,S3
Benzidine 联苯胺
Benzo[a]pyrene 苯并[a]芘;3,4-苯并芘
Benzofluoranthene 苯并荧□
Benzo[h]quinoline 7,8-苯并□□
Benzo[k]fluoranthene 苯并[k]荧□
Benzodiazepines 苯并二氮□类
Benzoestrol 苯雌酚 PP-S1,S2,S3
Benzoic acid 苯甲酸
Benzoyl chloride 苯甲□氯
Benzoyl peroxide 过氧化二苯甲□
Benzoylmorphine;its salts 苯甲□吗啡;其盐类 PP-S1
Benzquinamide 苯□胺(苯□□胺) PP-S1,S3
Benztropine and its homologues; their salts 苯扎托品与其同系物;它们的盐类 PP-S1,S3
Benzydamine; its salts □达明;其盐类 PP
Benzyl alcohol □醇
Benzyl benzoate 苯甲酸□酯
Benzyl chloride □基氯(氯化□)
Benzyl hydrazine 苯甲基□ PP-S1,S3
Benzylidene chloride 亚□基二氯
Benzylmorphine (3-benzylmorphine) □吗啡(3-□吗啡) DD
Benzylmorphine; its salts □吗啡;其盐类 PP-S1
Berberine hydrochloride 盐酸小檗□
Berkelium [Bk] □
Beryllium [Be] 铍
best estimate 最佳估计
beta blocker β-阻断剂
beta particle 贝他粒子
Beta-acetylmethadol β-乙□美沙多 DD
Betacetylmethadol β-乙□美沙多 DD
beta-Meprodine; its salts 倍他美罗定;其盐类 PP-S1
Betamethadol β-美沙多 DD
Beta-methadol β-美沙多 DD
Betamethasone 倍他米松 PP-S1, S3
beta-Prodine; its salts 倍他罗定;其盐类 PP-S1
Betaxolol; its salts 倍他洛尔;其盐类 PP-S1,S3
Bethanidine; its salts 倍他尼定;其盐类 PP-S1,S3
Bezafibrate 苯扎贝特 PP-S1,S3
Bezitramide 苯□米特 DD
Bezitramide; its salts 苯□米特;其盐类 PP-S1
Bicalutamide; its salts 比卡鲁胺;其盐类 PP-S1,S3
Bifonazole, its salts 联苯卡唑;其盐类 PP
bile acids 胆汁酸
Biochemical Oxygen Demand [BOD] 生物化学需氧量;生化需氧量
Biochemical Sciences Section 生化组
biological father 生父
biological tissue 生物组织
biological tissue sample 生物组织样本
Biperiden; its salts 比□立登;其盐类 PP
Biphenyl 联苯
Biphenylacetic acid; its salts; its esters 联苯乙酸;其盐类;其酯类 PP-S1,S3
bis(Chloromethyl)ether 双(氯甲基)醚
Bismuth [Bi] 铋
feixiong5134
第9楼2006/01/02
Bisoprolol; its salts 比索洛尔;其盐类 PP-S1,S3
Bitolterol; its salts 比托特罗;其盐类 PP-S1,S3
bituminous concrete 沥青混凝土;泊油路
blender 混合器
Bleomycin 博来霉素 AT
blood group substance 血型物质
bloodstain 血痕
blot 印迹
blotting, Southern 萨瑟恩印迹技术
blotting, vacuum 抽真空印迹技术
bodice 上身
Bomb Calorimeter 弹式热量器
Boric acid 硼酸
Borneol 冰片;龙脑
Bornyl Acetate 乙酸龙脑酯
Boron 硼
Boron trichloride 三氯化硼
Boron trifluoride 三氟化硼
Bottle teats 奶瓶奶咀
bottom sediment 底质;海底沉积物
Botulinum toxin complexes 肉毒毒素的复合物 PP-S1,S3
bradycardia 心搏徐缓
braking distance 制动距离
braking efficiency 制动效率
branching fraction 分支分数
bremsstrahlung 轫致辐射
Bretylium tosylate 溴□铵托西酸盐 PP-S1,S3
Brimonidine; its salts 溴莫尼定;其盐类 PP-S1,S3
British Pharmacopoeia 英国药典
British Standard [BS] 英国标准
bromate 溴酸盐
bromated vegetable oil 溴化植物油
Bromazepam 溴西泮 DD
Bromine [Br] 溴
Bromoacetic acid 溴醋酸(溴乙酸)
Bromocriptine; its salts 溴隐亭;其盐类 PP-S1,S3
Bromodifluoroethane 溴二氟乙烷
Bromodifluoromethane 溴二氟甲烷
Bromodifluoropropane 溴二氟丙烷
Bromodiphenhydramine 溴苯海拉明 PP
Bromofluoroethane 溴氟乙烷
Bromofluoromethane 溴氟甲烷
Bromofluoropropane 溴氟丙烷
Bromohexafluoropropane 溴六氟丙烷
Bromomethane (Methyl bromide) 溴化甲烷(甲基溴)
Bromopentafluoropropane 溴五氟丙烷
Bromotetrafluoroethane 溴四氟乙烷
Bromotetrafluoropropane 溴四氟丙烷
Bromotrifluoroethane 溴三氟乙烷
Bromotrifluoropropane 溴三氟丙烷
Bromvaletone 溴米那 (溴异戊□□) PP-S1,S3
Broncho-Vaxom 凡福舒 PP-S1,S3
Brotizolam 溴□二氮□ DD
Brotizolam 溴□二氮□ PP-S1,S3
Brucine 布鲁生 PP-S2
bubble flowmeter 气泡流速计
Bubbler (gas sampling) 气泡式吸收管
buccal cells 口颊细胞
Buclizine 布克利□ PP
Bucolome 布可隆 PP-S1,S3
Bufexamac 丁苯羟酸 PP-S1,S3
buffer strip 缓冲液纸条
buffer tank 缓冲液槽
Buformin; its salts 丁福明;其盐类 PP-S1,S3
Bumadizone, its salts 布马地宗;其盐类 PP-S1,S3
Bumetanide; its salts; its derivatives; their salts 布美他尼;其盐类;其衍生物;它们的盐类 PP-S1,S3
Bupranolol; its salts 布拉洛尔;其盐类 PP-S1,S3
Buprenorphine; its salts 丁丙诺啡;其盐类 PP-S1,S3
Buserelin; its salts 布舍瑞林;其盐类 PP-S1,S3
Buspirone; its salts 丁螺环酮;其盐类 PP-S1,S3
Busulphan; its salts 白消安;其盐类 PP-S1,S3
Butane 丁烷
Butorphanol; its salts 布托啡诺;其盐类 PP-S1,S3
Butylated hydroxyanisole [BHA] 丁基羟基甲氧苯
Butylated hydroxytoluene [BHT] 二丁基羟基甲苯
Butylchloral hydrate 水合丁氯醛 PP
Cabergoline; its salts 卡麦角林;其盐类 PP-S1,S3
Cadmium [Cd] 镉
Cadmium oxide 氧化镉
Caffeine 咖啡因
Calabar bean, alkaloids of 毒扁豆生物硷 PP-S1,S3
Calcipotriol; its salts 钙泊三醇;其盐类 PP-S1,S3
Calcium [Ca] 钙
Calcium carbide 碳化钙
Calcium carbonate 碳酸钙
Calcium hypochlorite 次氯酸钙
Calcium sulphate 硫酸钙
feixiong5134
第10楼2006/01/02
calibration 校正
calibration (in analysis) 定标(分析过程中)
calibration (instrument) 校准(仪器)
Californium [Cf] □
caliper 测径器
Calomel 甘汞
calorimeter 量热器
Camazepam 卡马西泮 DD
Camphor, synthetic 樟脑,合成
Candesartan; its salts; its esters; their salts Candesartan; 其盐类;其酯类;它们的盐类 PP-S1,S3
Candicidin 杀念菌素 AT
canister (gas sampling) 金属气体采样罐
Cannabinol and its tetrahydro derivatives; their 3-alkyl homologues 大麻酚及其四氢衍生物;其3-烷基同系物
Cannabinol and its tetrahydro derivatives; their 3-alkyl homologues; any ester or ether of any substance falling within this item 大麻酚及其四氢衍生物;它们的3-烷基同系物;任何属此项范围内的物质的酯类及醚类 PP-S1
Cannabinol and its tetrahydro derivatives; their-3-alkyl homologues 大麻酚及其四氢衍生物 ; 其3-烷基同系物 DD
cannabis 大麻 DD
cannabis resin 大麻树脂 DD
Cannabis; the resin of cannabis; extracts of cannabis; tinctures of cannabis; cannabin tannate 大麻;大麻的树脂;大麻浸膏;大麻酊剂;鞣酸大麻素 PP-S1
Cantharidin 班蟊素 PP
Cantharidin; cantharidates 班蝥素;班蝥酸盐 PP
capillary column 毛细管柱
Capillary Electrophoresis [CE] 毛细管电泳
Capillary Gel Electrophoresis [CGE] 毛细管凝胶电泳
Capillary Zone Electrophoresis [CZE] 毛细管区带电泳
Capremycin 卷曲霉素 AT
Capreomycin 卷曲霉素 AT
Captodiamine; its salts 卡普托胺;其盐类 PP-S1,S3
Captopril 卡托普利 PP-S1,S3
Caramiphen; its salts 卡拉美芬;其盐类 PP-S3
Carbachol 卡巴胆硷 PP-S1,S3
Carbamazepine 卡马西泮 PP-S1,S3
carbetapentane 咳必清
Carbidopa; its salts 卡比多巴;其盐类 PP-S1,S3
Carbimazole 卡比马唑 PP-S1, S3
Carbomycin 卡波霉素 AT
Carbon [C] 碳
Carbon black 碳黑
Carbon dioxide 二氧化碳
Carbon disulphide 二硫化碳
Carbon monoxide 一氧化碳
Carbon soot 碳烟灰
Carbon tetrachloride 四氯化碳
Carbonyl chloride (Phosgene) 二氯化羰□(光气)
Carboplatin 卡铂 PP-S1,S3
Carboxyhaemoglobin 碳氧血红蛋白
Carbromal 卡溴□ PP-S1,S3
Carbutamide 氨磺丁□ PP-S1,S3
carcinogenic amines 致癌胺
Cardamonin 小豆蔻明
Carisoprodol 卡立普多 PP-S1,S3
carminative 驱风剂
Carmustine 卡氮芥 PP-S1,S3
Carperidine; its salts 卡□利定;其盐类 PP-S1,S3
Carprofen; its salts 卡洛芬;其盐类 PP-S1,S3
carrier 载体
carrier ampholyte 载体两性电解质
Carteolol; its salts 卡替洛尔;其盐类 PP-S1,S3
Carvedilol; its salts 卡维地洛;其盐类 PP-S1,S3
catalyst 催化剂
cathartic 泻剂
Cathine 去甲麻黄□ DD
Cathinone 卡西酮 DD
cathode 阴极
cation 阳离子
Caustic potash (Potassium hydroxide) 苛性钾(氢氧化钾)
Caustic soda (Sodium hydroxide) 苛性钠(氢氧化钠)
Cefadroxil 头孢羟氨□ AT
Cefalexin 头孢氨舂□ AT
Cefalothin sodium 头孢□吩钠 AT
Cefazolin 头孢唑□ AT
Cefoperazone 头孢□酮 AT
Cefotaxime sodium 头孢□□钠 AT
Ceiling Exposure Limits [CEL] 最高暴露限值
Celecoxib; its salts Celecoxib;其盐类 PP-S1,S3
Celiprolol; its salts 塞利洛尔;其盐类 PP-S1,S3
Cellulose nitrate 硝酸纤维素
Central Database System 中央资料库
centre of gravity 重心
centre of mass 重心
centrifugal force 离心力
centrifuge 离心机
