vee050328
第6楼2011/03/15
楼主,从这个事情上来看好像是客户有理吧,因为你没有办法用数据来证明它是FAIL的,如果仅仅从脱色来判断是否合格是不对的吧,而且全面迁移中没有说过脱色就是FAIL啊。
我们的投诉么经常出现在FDA中,熔点什么的
两个字的烦恼
第7楼2011/03/15
欧盟1935-2004-EC中有这么一个条款
Article 3
General requirements
1. Materials and articles, including active and intelligent mate-
rials and articles, shall be manufactured in compliance with good
manufacturing practice so that, under normal or foreseeable con-
ditions of use, they do not transfer their constituents to food in
quantities which could:
(a) endanger human health;
or
(b) bring about an unacceptable change in the composition of
the food;
or
(c) bring about a deterioration in the organoleptic characteris-
tics thereof.
要求不会对食物成分发生改变,不会导致感官的劣变。
vee050328
第8楼2011/03/16
但是你做的是全面迁移呀,要按照全面迁移的要求来啊,全面迁移不包括感官的好不?
举个例子如果我做玩具做出来总铅是有数据但是不FAIL但是呢我用的ICP 来读数据所以我看到它Cd超标了,我不能判它FAIL啊
