笨笨的唯一
第1楼2011/03/23
In the special case in which a procedure is adapted to the working range of an instrument, solution concentrations may differ from the indicated value by more than ten percent (10%), with appropriate changes in associated calculations.
在特殊情况下,程序的目的是去适应仪器,溶液的浓度可能不同于指示值,这个差别能达到10%左右,这是在计算允许的范围之内的。
依然感觉到驴唇不对马嘴呢
sjbsjbsjb
第4楼2011/03/23
在特定情况下,如程序能适应仪器的工作范围,加上在计算中适当的变化,溶液的浓度可以超出于指示值的10%。
poorlittle
第5楼2011/03/24
The original is ambiguous.
more than ten percent : 11%, 25% or even 120% are more than ten percent
I suppose that the original may mean “differ from the indicated value by up to ten percent (10%)”, i.e. if the indicated concentration is 50, solution concentration of 45 to 55 are acceptable.
(please note that“differ” may be positive or negative)
Or “differ from the indicated value by not more than ten percent (10%)”
